Question about Dacor MCS230 Millennia Electric Double Oven
Dacor oven won't heat after self clean
Posted by Johnny McIntosh on
3 Related Answers
Anonymous
SOURCE: My Dacor wont heat, broil or convection after self cleaning
I also have a Dacor Model PCS130. This solution worked AND saved me from spending $50-$105 for a service technician to come out just to look at the problem. The high temperature sensor tripped when I kept the door open part way while broiling (never listen to friends who don't have the same oven as yours). Afterwards, I couldn't get the oven to go above the prebake temperature of 135°F using any of the settings (bake, broil, convection bake, etc...). I called Dacor customer service and they told me about the high temperature sensor but wouldn't say how to reset it. They suggested I call a third party technical service company and gave me their numbers. But, I'm glad I found this site... All you have to do is open the oven door and you'll see the grille/grate/steel cover plate where the door latch sticks out of. If you look inside, you can see the electronics that operate the door latch as well as the temperature sensor unit a little farther back. You can even see the RED reset button. But, it's a little too far back for you to press it without removing the cover plate. 6 screws is what holds my cover plate in place. Once that's off, you can reach in and press the RED reset button (I pressed it twice just to make sure) and you'll hear it click. Screw the cover plate back in place. Close the oven door and test it out. It took my oven about 5 minutes to heat up past 135°F so I was unsure if the problem was fixed or not during that time. But, once the oven heated up sufficiently, the temperature began climbing fairly quickly and I was able to breath a sigh of relief. It works! This is such an easy fix, I don't know why Dacor customer support doesn't just tell us how to do it ourselves instead of paying for a service tech to come out and do the same thing. Even better, maybe they should make the reset button more easily accessible (like on the control panel) if they're concerned about people getting in and messing up the other electrical connections when trying to reset the high temperature switch. Computers are far more technically advanced than your oven and THEY have reset/reboot buttons right in front.
Posted on May 30, 2007
Anonymous
SOURCE: dacor oven ECPS127S will not heat after self clean
the problem was fixed by opening the panel between the oven cavity and the touch panel just behinf the door. you can look through the grill but to trip the reset you must unscrew the panel. you will find the reset back behind the wires Looks a red button nestled on top not very open but it should be there> i do have to say i found a step by step description on this site. but right now i can't tell you who exactly he was.
Posted on Feb 24, 2008
SOURCE: dacor oven self cleaning instructions?
Go to link below and get the manual for your model. http://tv.manualsonline.com/ex/thread/view/idThread/1185347
Posted on Mar 10, 2010
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
Put oven through self clean for 2 hours. Oven
What has happened is IF the temp gets to hot in the electronic controls area, an in line fuse/limit burns out and shuts down everything.
I have a DACOR tech sheet HERE
So what I think is happening is the in line fuse in the wiring harness could be blown. You won't know till you or someone checks.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 15, 2010 | Dacor Ovens
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
I don't know how to clean the oven
You should have a function switch that says " self clean ". Normally, all you have to do is turn the control on to "self clean" and let the oven do the rest. It will take about 3 hours or so to complete the cycle.
Jan 30, 2009 | Dacor ECS127 Epicure Electric Single Oven
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Dacor epicure electric oven
On my Dacor oven whenever I use the self cleaning feature it trips the breaker and the oven doesn't heat up. It can be reset, but you need to take off the front panel and reach way back for the red reset button.
Nov 04, 2007 | Dacor ECS130 Epicure Electric Single Oven
Dacor MCS230 Millennia Electric Double Oven Logo
130 people viewed this question
Top Dacor Ovens Experts
Paul Bade
Vincent G
Vincent G
ray gallant
Are you a Dacor Oven Expert? Answer questions, earn points and help others
