Nikon D3000 10.2 Megapixels SLR Digital Camera with 18-55mm VR & 55-200mm DX VR Lens Kit Logo
Sherif Nazir Posted on Nov 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memory card cannot be used but when i put the card in my lap it works very well .
  • Bart Pulverman Oct 10, 2014
    Hi Sherif Nazir, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Have you tried reformatting the card in your camera?
Bart Pulverman
Level 2:
Guru:
  • Nikon Expert 362 Answers
  • Posted on Nov 05, 2015
Bart Pulverman
Nikon Expert
Level 2:
Guru:
Answers
362
Questions
0
Helped
83718
Points
625
First make sure that your SD card is not write protected. Look on the edge of the SD card and you will see a very small slide switch. Slide it to the unprotected position. This feature is to allow you to prevent accidental erasure of the memory. If that does not solve your problem, make sure that you format the SD card in your camera; not on your computer. If you go into your camera's menu you will see where you can tell the camera to format the SD card. If that does not work, try another SD card.
1helpful
Memory card not working
use external usb card reader for that
2answers
I put my psp memory card into the sd slot and now it wont come out wht shall i do?
Try using tweezers or very small needle nose pliers to get your memory stick pro duo out of the SD slot.
Well i am going on a trip tomorrow and i put my memory card into the lap top and put all pix on the lap top and then put it back in to the Nikon and i gray screen came up and said that "momory card is writ...
Some memory cards have a small plastic tab on the side of it that can be set to write protect the card. Check your card to make sure the tab didn't get moved accidentally.
When putting music or pictures on pny 4gb mirco sd card from my hp pavillion dv7-1247d lap top than put card in my samsung sch-r451c phone it shows up on memory but can not see or play music. yes I first...
I dont have a solution, but my aunt purchased this phone and a new SD card, and I have put pictures and music for ringtones from my computer to the SD Card, and when I put it back into her phone (Samsung R451C) I can not bring any of the pictures up and I can bring the music for the ringtones, but I cannot set it as a ringtone. I am sure if I was able to bring the pictures up, that I probably would not be able to set them as a wallpaper or nothing also...So I kind of have the same problem with setting my aunt's pictures and music with the same phone too...
I left my memory stick in my lap top. Dislodged
i guess you just broke the usb.. try to connect on other pcs if still works...hope this helps..
2helpful
2answers
Card not working
Plug into a PC with memory card reader and format it. If not, it is corrupt and needs replacing.
Memory Card for digital Camera
After inserting the card, go to my computer and see if it shows the memory card inserted. If so, click it and then when it opens, click copy to location and you choose the location, easiest, my documents and then my pictures.
Dec 26, 2007 • Cameras
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
