With the main dial on top of the camera, set it on Auto(magic). When it is in a scene mode, it can't adjust to the right settings.
Use the menu button.
When it is set to Auto and you get the same result, I'm afraid there is another problem. But if the pictures are better, only use a mode you understand. (To start with scene and chose a mode you need)
White shadow or white lines may occur if the light was too bright when you take the picture, especially in strong sun light. Have you turn off the flash light when you taking those picture ? If you haven't, then you should try to turn off your camera flash light manually. And I must remind you not to take a picture with your lens faced the sun light or other light (lamp etc) directly. Even if you take a picture outdoors, try to make your lens shaded by something, you can even use your own shadow to shade them.
Hi!
No, it's not a software problem. The problem is that the shutter
doesn't work so it can't control the amount of light taken so the
pictures are very bright with horizontal lines. There are usualy two
causes - a broken shutter cable inside the lens or the shuuter blades
are stuck - may happen if the lens get wet or something adhesive gets
in it. It's a hardware problem so I suggest you contact local Canon or
other camera service center. It is considered a hard repair so it could
get expensive. I don't think it's worth it, so I would suggest you get
another camera.
u are covered dont worry it is a
manufac fault inn CCD's ur camera manufacturer will do it Free of charge pls see the link
and call them and PLS RATE ME FIXYA for help
http://www.imaging-resource.com/badccds.html
dont worry if u are not on list just call them ! pls dont forget to rate me
shutter is sticking so it over exposes photos . will need shutter or lens assembly replaced. it will have banding stripes in low light and white in bright light.
If the photo shoot out show white , the obscure (quality
variation), and even horizontal line ( white lines), and so on over-exposure
cases, even if the use of anti-tremor, set to default values are invalid,
because the camera shutter fault.
The shutter is stuck. The electronic "noise" created by the solenoid trying to move the shutter blades causes the lines on your pictures. The bright outdoor pictures is due to the fact that the shutter is jammed open.
You can try tapping the camera on the sides and bottom. This may jar the baldes loose. Failing that, you will have to find a shop that can obtain a replacement lens assembly for your camera.
