Question about U-Line CO2075F-B Echelon Refrigerator Ice Maker Combination
SOURCE: dometic rm2611 not restart after cooling box normally, then warmi
I would replace the thermister and also check the gas soleniod. Don't those get weak once they get hot or warm. Hope this helps.
Posted on May 10, 2009
SOURCE: Intermittent cooling it will only restart when
did you try changing the cold control part# wr09x10042
Posted on Jun 30, 2009
SOURCE: U-line CO 2075 refrigerator stopped working, only
OK I'm guessing you have a clear icemaker. Not a co2075. When you replace the board you MUST replace the thermistors that come with the board. The board and thermistors are calibrated together. What is your model number? A clear ice maker has thermistors inside tubes. Except for the one on your filter dryer. Lets start with the correct model.
Posted on Aug 21, 2009
SOURCE: I have a U-Line 75 Bev and need to replace the
Call U-LIne at 800-779-2547
Posted on Mar 02, 2010
SOURCE: U-line refrigerator model u-1175rw
E3 stands for door open longer than 20 minutes, It may be bad door switch, door switch magnet misalign. You can test the door switch when you open and close the door, it should make a clicking sound, if not, you door switch either is bad or misalign.
Posted on Mar 07, 2010
Jun 02, 2018 | Kenmore Dryers
on Jul 19, 2010 | Washing Machines
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in
heat mode. On cooling, the E5 will appear if the outside coil temp exceeds 68C. This is an indication
of condenser airflow reduced or non-existent. Using the procedure described above it is possible to
watch the condenser coil temp using the Temp down button and Medium fan speed combination to
display this temp. NB: if fans etc seem to be OK then measure thermistor resistance and refer to table
12. In case the problem is thermistor calibration.
Action: If unit is in cooling mode, examine both condenser fans are running. If
one is running then suspect a faulty motor. If both fans not running then
on units up to serial No. IBSA 01175, investigate the fan speed control
card located in enclosure on the LHS See fig 6.
If this checks OK then investigate main control card.
Fig 1, 2 or 3. Units with serial No's IBSA01176 and
onward are multi speed tapped wound motors not requiring a speed
control card. If both motors inoperative then suspect main control card
Aug 15, 2016 | Heating & Cooling
Sep 19, 2014 | Heating & Cooling
Oct 09, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Sep 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Aug 21, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
May 13, 2009 | Canon NP 6085 Copier
Jun 09, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Nov 04, 2013 | U-Line CO2075F-B Echelon Refrigerator Ice...
93 people viewed this question
