Do not have the orig harness that came with the deck. Dual no longer makes these kind of decks...nor the harness to suppport it... where do i get the diagram of the color wire coded harness, so i may create my own custom harness? im trying to avoid crosss wiring the deck and blowing it by putting a speaker wire connect to the ground or something ya kno...
SOURCE: What wiring harness and deck install kit?
My husband and I just installed a Pioneer DEH-2000 MP today in my 2004 Sentra, which we bought at Electronic Express. They didn't have the wiring harness or the install kit we needed, but Best Buy did. Just go there or some other electronics/car audio place and tell them what vehicle you are installing your stereo into. Make sure you do have all the same color wires and numbers of them on your harness(s) as you do for your stereo - they should of course match, and the plugs of the harnesses will match those of your truck. Don't freak out if you don't use all the plugs in your truck though - one may be left because it was proprietary to your stock radio. A couple of good install kit brands are Scosche and Metra - both use factory colors and molding that will match the color and lines of your dash to make it look as integrated as possible.
Hope that helps!
SOURCE: 1999 Grand Cherokee Radio Wiring Harness Diagram/Color Codes
Go to www.installdr.com and search through the diagrams in there, the site is easy to use, all you need is acrobat reader installed on your computer to use the site, it has a full explanation on every wire color and what it is
SOURCE: dimmer wire connection from aftermarket delco harness to alpine
One Of The Wires Should Be labeled Dash Lights That Comes Out Of Your Radio.
SOURCE: im tryin to replace the tape deck in my ford ka
Rather than cutting wires i'd advise you to buy a pc2-17-4 autoleads ford harness. you can get them in a shop such as halfords or on ebay for between £3.50 to £10. You can plug this directly into the car and straight into the radio you are installing provided it has a standard iso block on it. it means when you sell car you can reinstall the old radio and take new one with you. Plus no tedious wire cutting.
SOURCE: Need wiring harness color coded diagram for pioneer dehp6800mp.
Hello randscates,
Here's a link to the manual. The wiring color code for the supplied harness is on page 78. The diagram is rotated 90 degrees clockwise. I recommend that you download the PDF and print out the page you need.
Hope this helps.
