Question about Alpine PDX-1.600 Car Audio Amplifier
Blue light on but not output
Not working but Blue Light is on
Posted by Lorne Binfield on
Lorin Thwaits
    New Friend:
  • 3 Answers
Also make sure you are using the speaker connectors properly. The + and - wires should end up on the OUTSIDE of the connector, not the inside, when the allen wrench thing is torqued down.
Posted on Oct 06, 2015
Colin Stickland
  • 22,485 Answers
It has power but it may not have any input and without a good look myself i wouldnt know offhand as to where to tell you were to look sorry
Posted on Nov 23, 2011
Can blue light come on even with a blown fuse?
not if the fuse is for the blue light and there is not a short giving power to the blue light. If the fuse for the blue light is blown power must be coming from a short circuit ....lights do not work on their own
Jul 17, 2015 | Cars & Trucks
Keyboard quit working; blue charge light on
faulty power adapter port, may have blue light meaning charger is working normally, double check with another working power adapter or use your adapter with another keyboard to check which device has problem, power adapter or keyboard port.
Oct 12, 2014 | Targus 90W AC Universal Wall Power Adapter...
I need a radio wiring diagram
Constant 12V+ Green/Purple
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination Light Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
best wishes
Jan 01, 2011 | 1992 Ford Explorer
Link light on (blue), activity light off (neither blue nor red)
Press the RESET button on the back of the unit and reconfigure the settings.
Sep 11, 2009 | Linksys Wireless-G Range Expander (WRE54G)
Putting in a alpine deck into my cirrus
Constant 12V+ Pink/Yellow Switched 12V+ Red/White Ground Ground/Back Strap Illumination Orange/Brown Dimmer Black/Light Blue Antenna Trigger Orange/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Light Green/Green Left Front (-) Light Green/Purple Right Front (+) Light Blue/Green Right Front (-) Light Blue/Purple Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Blue/Light Blue Right Rear (+) Dark Blue/White Right Rear (-)
Dark Blue/Orange
Mar 28, 2009 | Alpine CDA-9847 CD Player
Red Light/Blue Light I/O Error
My nx2 is working again after having the "red light/blue light/I/O Error" problem. I just:
1. turned off my computer
2.unplugged the HD,
3. took out the HD from the enclosure and plugged it back into the enclosure,
4.started up my computer without the HD being plugged in
5. after my computer had been on for a minute, I plugged the HD in and my computer recognized it and had the proper mixture of red and blue light coming from the HD, indicating it's working properly.
Aug 26, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Blinking blue light
the only blue light that i know blinks is the Kmart blue light special .. we need model of things you're working with to properly diagnose.
is it external drive ? with a blue light blinking ? is it connected in usb ? sounds like if its external drive with blinking light could be bad hard disk or bad controller card inside that translates ide to usb.
Jul 29, 2008 | Computers & Internet
Tfi module wiring diagrahm
What I got from Ford is not working on mine #1 is bottom wire black orange,white light blue,red light green, red light blue,yellow light green, top is dark blue? I don't have a dark blue wire? I have a white wire?
May 18, 2008 | 1984 Ford F 150
Blue light?
Sounds like you have the blue tooth on. I think that is what the blue light is for... The black screen I have no clue, i am sorry
Mar 03, 2008 | Motorola Mobility RAZR V3
Alpine PDX-1.600 Car Audio Amplifier Logo
326 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
