Question about Mitsubishi WD-57731 57" Projection HDTV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 and the picture disappeared bu there was still sound. The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Posted by Donald Slaughter on
Henderson Electronics
    New Friend:
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Posted on Dec 19, 2013
5 Related Answers
shaun taylor
  • 1527 Answers
SOURCE: lamp wont light. Green then Red on power. Orange
hello The lamp cover is ajar. Firmly replace the cover
shaun
Posted on Oct 24, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: wd-52525
Sounds like the Capacitors on the PWB PCB You can get a repair Kit to fix that its called V26 PWB PCB kit at the following link. It contains the different capacitors and a CD with the info on the repair. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 28, 2008
jason
  • 905 Answers
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Posted on Oct 18, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Lamp problem
The DM is failing to complete the boot sequence thats why the power led is continuously blinking green. The V26 DLP DM repair kit will usually repair that issue you can get the kit at the following link which includes the replacement capacitors and step by step instructions with pictures on how to do the repair.Its listed under the repair kits category.
Posted on Mar 26, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: WD 62725 Timer geen light keeps blinking
Thats caused by the capacitors on the dm which wont allow the DM to boot back up because the power cord was unplugged to change the lamp. You can get the V26 DLP DM repair kit at the following link which will usually repair that issue and it contains the replacement caps and step by step instructions with detailed pics on how to do the repair on CD plus the service manual is also on the CD.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Posted on May 26, 2009
Blinking yellow light on Mitsubishi wd 57731
Based on the service manual:
Blinking yellow= Lamp cover is open.
It could be something else!
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD-57731 57" Projection HDTV
Mi problema es con mi mi televisor mitsubishi vs-50501 enciende y cuando va a entrar la imagen se apaga a veces si entra y se ve medio rara como que tiene dos imagenes un poco separada o se ve la imagen...
Dec 19, 2013 | Mitsubishi VS-50609 50" Rear Projection...
WD-57731 Will turn on, I get sound but no picture.
You should be able to see if lamp itself is lit or not, if lamp does come on or has been replaced recently let me know, I have a idea or two but need more information if possible.
Oct 14, 2012 | Mitsubishi WD-57731 57" Projection HDTV
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Blinking orange lamp light
if the lamp light is flashing and the tv won't come on you need to replace the lamp. check your owners manual for how to do it or call mitsubishi customer service
Jan 26, 2010 | Mitsubishi WD-Y57 57" Projection HDTV
Model WD-57731 LED Timer Light
You have a dm board problem could be the capacitors or you may need to change the entire board.
Sep 16, 2009 | Mitsubishi WD-57731 57" Projection HDTV
57" Mitsubishi won't power on, blinks green timer light
It is a common failure of the 57" Mits. DLP. The problem is a defective thermistor and is covered by Mits. Contact a local repair shop and they will fix it free (parts & labor)
Sep 04, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Mitsubishi WD-57731 57" Projection HDTV Logo
1,950 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
