The flash also not working and sometimes its shaking or vibrating..how will i fix it?
SOURCE: LANGUAGE SETTING JAPANESE TO ENGLISH
Hello analyn
There may be a simple fix to this problem.
Find a friend that has a cybershot of the same model as your own. In their camera, open the menu and navigate to the language setting. While you do this count how many times you press the button. Example:
Menu
-camera settings 1
-program 2
-personal settings 3 press ok
personal settings
-storage type 1
-date and time 2
-language 3 press ok
language
-spanish 1
-english 2 press ok
-japanese
Although the language is different, the number of spaces should be the same, so even though you can't read it to change the language, you should be able to count it out. Or if you are lucky you may have a Japanese friend who can read it.
Hope this helps
-Chris
SOURCE: change language from japanese to english
Does this help? "Changing the Language Setting" is located on the first page towards the bottom. It instructions of the symbols you select to reach the language section.
http://www.docs.sony.com/release/DSCW30-W40-W50-W70_rtf.pdf
If this doesn't work could you try using google translate the locate the language section?
http://translate.google.com/#ja|en|
SOURCE: How to switch language on japanese bought sony dsc-wx1 cybershot?
I bought a camera in Japan (Sony Cybershot DSC-WX1) and now it seems that i can't change the language from japanese to english. If i select (can't read it but with the help of the english digital guide i think i have the right menu)change language, there seems to be only one language available. -japanese- How do I solve this?
SOURCE: how do i translate my sony dsc-w50 digital camera
If there's no English in the language select menu (in setup), the region has to be changed. This can only be done with Sony SEUS software which is available for Sony service centers only. You could ask Sony how much would it cost to change the region (aka "destination" in the SEUS). I have worked in a Sony service center and I have done it before.
SOURCE: sony cybershot dsc-w270 japanese to english settings??
Press the MENU button to bring up the main menu. Use cursor-down to select Settings (toolbox icon) and press * in the center of the cursor pad. Use cursor-up/down to select Main Settings (wrench and hammer icon), press cursor-right, and then *. Select the second item on this menu.
