Thompson dvd player unlock code dv2137
Need tio unlock dvd region
Posted by peter on
spainte
    New Friend:
Just bought THOMSON DV2137 in Australia (region 4) It plays Aus but not US. A small slip in the user's manual gave these (verbatim) instructions. UNFORTUNATELY it isn't working on my player."This unit has been set to play region 4 DVD discs. If you wish to use this unit outside of region 4 territory you can change the region setting by following the instructions below.1) Turn on the unit.2) Remove disc and press SETUP to enter SETUP menu.3) Press VOL+.VOL-,VOL+,VOL-, by order, then press MUTE to enter Region Code setting. [stays in SETUP menu]4) Press LEFT / RIGHT to choose between 1-4 or ALL region."
Perhaps this will work for someone else or will trigger a clue.
Posted on Jan 07, 2012
darren_gedye
Like you my Thomson DV2137 came with the instructions on a slip of paper in the box. This is what I do.
Remove dvd from tray, close tray, and turn off.
This next bit seems to be time sensitive, and you have about 3 seconds, so make sure you know where the vol and mute buttons are.
turn on
press setup vol+, vol-, vol+, vol- mute
that brings up a screen with the region settings. Use left/right buttons to select the zone you want, or use ALL.
press setup.
open the tray and insert dvd.
Sadly this seems to be a temporary fix, and when the machine is turned off it returns to the default.
Posted on Jul 28, 2012
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: Philips DVD player dvp 3580 regional unlocking code
1. Press the Setup button on your remote control
2. Using your remote control, highlight but do not
select the Preferences menu
3. Press the 1 button on your remote control
4. Press the 3 button on your remote control
5. Press the 8 button on your remote control
6. Press the 9 button on your remote control
7. Press the 3 button on your remote control
8. Press the 1 button on your remote control
9. Using the Up and Down buttons on your remote
control select 1 for region 1, 2 for region 2, and so on, or
0 for multi-region playback
10. Press the OK button on your remote control
11. Press the Setup button on your remote control
Posted on Aug 16, 2010
Anonymous
SOURCE: unlock regional code
I found the solution here.
http://www.videohelp.com/dvdhacks/lg-dv480/10008
Region code hack posted by vassmanov, March 23 2009:
Press the Pause button on your remote control. Using your remote control enter the code 3,1,4,1,5 and 9, At this point, a blue screen displays showing that you are in 'region altering mode'. Press the 0 button on your remote control for Region free. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player and your ready to go!
It worked for me (after a few false starts)
Posted on May 09, 2009
Anonymous
  • 1463 Answers
SOURCE: unlock region codes
hi
try this DVD Player, Blu-ray and HD DVD Player region codes
see if any help to you.
riz.
Posted on Mar 07, 2008
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: Unlock codes
This player is manufactured by the Funai Corporation for Magnavox. This is a very basic DVD player.
After speaking with the Funai Corporation Support Line, they have no problem giving out region hack codes for other models they make such as Symphonic, Emerson, as long as the user understands if you make a mistake and something happens, not their fault, etc.. For this basic player - No codes exist. Sorry..
Posted on Oct 30, 2008
Anonymous
SOURCE: need region code for dvd player sony dvp-sr200p
unlocked dvd sony dvp sr200p code
Posted on Dec 18, 2010
Unlock dvd region
Directly follow the guide to unlock the DVD region code. it works good http://drm-assistant.com/dvdtips/how-to-bypass-dvd-region-code.html
Jan 07, 2014 | Computers & Internet
Unlock region code
You maybe able to get a region free code for your player from one of thede WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Feb 09, 2013 | Televison & Video
I need to unlock the region on my murphy dvd player
You maybe able to get a region free code for your player from these WEB sites.
Jan 31, 2013 | Televison & Video
Unlock region code for JVC dvd player
if your dvd player is not region free it will not play us dvds it will only play burnt dvds and dvds from your region unless u buy a region free dvd player
there is no region free code for your dvd player
Apr 04, 2009 | JVC XV-E100SL DVD Player
Need code for durabrand portable dvd player
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
I need a way to unlock my samsung dvd v9650 so its multi region
Not all models can be unlocked. It is now possible to buy a region free DVD player. If your player cannot be unlocked, then you will have to invest in to a region free DVD player.
eHow, Info About Unlocking DVD Players:
http://www.ehow.com/how_2167872_unlock-dvd-player-area-code.html
DVD Help:
Jerry G.
May 24, 2008 | Televison & Video
Unlocking Region Codes for NEC NDT 44A
TO UNLOCK NEC NDT-44A
1. Press EJECT
2. Enter 0, 0, 0
3. Enter the region you want (0 = multi-region)
4. Press PAUSE
(I feel like I just won the lottery!)
May 16, 2008 | Televison & Video
Unlocking code for Samsung V6700 DVD/Video combi for region 1
I need to unlock (play any region) GPX D1816 DVD
Any help appriciated
Thanks
Jan 20, 2008 | Televison & Video
PERMANENT UNLOCK REGION CODE FOR philips DVD PET714
I boght PET714 DVD portable DVD player.
but I couldn't watch Japanese DVD.
I'd like to unlock code.
Please tell me how to get unlock!!
Jan 12, 2008 | Televison & Video
UNLOCK REGION CODE
you can't unlock a DVD player....
if it is a DVD drive for a computer you can watch movies with VLC because it ignores the region codes.
Oct 25, 2007 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Televison & Video Logo
4,734 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
