Sony CRX835E CD-RW/DVD-ROM (Combo) Burner Logo
Anonymous Posted on Nov 22, 2011
Sony CRX835E CD-RW/DVD-ROM free drivers
Windows xp service pack 2.cd rome device is not being detected and installed
Brian Sullivan
Level 3:
  • Sony Master 27,725 Answers
  • Posted on Nov 23, 2011
Brian Sullivan
Sony Master
Level 3:
Answers
27725
Questions
Helped
5664220
Points
79191
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
  • Brian Sullivan
    Brian Sullivan Nov 23, 2011
    if you dont have motherboard disk you will need to download the drivershttp://download.cnet.com/dvdram-en-20071...
    http://download.cnet.com/dvdram-en-20070...
    http://download.cnet.com/dvdram-win2k-50...
    http://download.cnet.com/adaptec-udf-rea...
    Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
    hope this helps you
  • Brian Sullivan
    if those drivers were not righthttp://download.cnet.com/slimdrivers-fre...
    http://www.driver-fix.com/scan.php?id=sc...
    note: it will find all of your outdated drivers
    both of these are free driver solutions
    they will automatically search for and for the correct driver
    hope it helps you
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html
http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
hope this helps you
2answers
Drivers for sony cdrw dvd crs8435e missing
try to find the driver in the cartoon of your cd-rw/dvd-rom, or you may visit any sony service center in your area they have a driver in there. thanks
2helpful
MY SONY CRX835E-DF CDRW WILL NOT WORK. i AM TRYING TO FIND A DRIVER FOR IT TO FIX THE PROBLEM
Hello mychella513, hi, there is no need for you to find the device driver for your sony combo, because its already present in windows. If you cannot power on the device or the computer cannot detect your drive, its defective, Windows has already installed the device driver for CD/DVD for your computer.
My dvd rw reads a dvd and then says my hardware is a cd rom
i wish i could help you.. but my sony is haven problems too. im running windows xp.. service pack 3.. i've already updated all drivers.. uninstalled it from device manager.. n it still isn't reading any cd-r cd-rw cd's.. my windows does read the device.. n it pops up everytime i load the computer up!
2helpful
2answers
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Redone windows xp.... now cant burn dvds
There are dozens of free perfect functioning  burning software. the one that i use is Totally Free Burner 3: as the name says it's free, extremely small ( just 1 MB compared to 100MB for Nero), fast and very easy to use. get it from here http://www.softpedia.com/get/CD-DVD-Tools/Audio-CD-DVD-Burning/Totally-Free-Burner.shtml
In side device manager sony cdrw/ dvd crx835e shows an explaination mark... cds, and dvds aren't able to be read from the drive
it means that your driver for that device is not completely install. so reinstall the driver.
thanks for your question
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
