Pioneer AVIC-F910BT Car Video Player Logo
A
Anonymous Posted on Nov 22, 2011
Lost password for Pioneer AVICF910BT and want to reset
I need to reset my AVICF910BT satnav but cant work out how? The unit is asking for a password and I cant remember it.
Level 3:
Top Expert:
  • Pioneer Master 76,851 Answers
  • Posted on Nov 22, 2011
Pioneer Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006139
Points
237762
Hello
If you did forget the password, there is no other way than contacting the nearest authorised Service center for Pioneer at your town. No adjustments cannot be done with this set, except deleting the present password. But to delete the present password, you must have the original password you did set at first. OK.
  • Anonymous Nov 23, 2011
    Thank you for your help.
Lost remote for pioneer media receiver PDP ro6g stuck on standbys how to fix until get new remote
Do a hard reset on the receiver to see if you can get it to work. Or contact Pioneer and ask for a hidden code to restore the unit to factory defaults. If nothing works you are SOL
Lost cd download
What exactly do you need the cd for? If you set it up and cant remember how to access it, lost password etc, I would suggest resetting it to factory defaults by holding the reset button in for 10-15 seconds. After the reset, access it using a wireless connection (it should be called ciscoxxxx where the "x"s are numbers) and it should prompt you to go through the auto setup process again. If it asks for a password, the default password for the wifi should be on the bottom of the router. Rather than the password or key, it may ask for an 8 digit pin number also found on the bottom of the router.
Manual for 2401g velo model
Can anyone provide the default password to this system
Where can I buy a map card with the United Kingdom info be bought in Canada?
Go to www.garmin.com and if you've registered your satnav log into myGarmin.
Click on the myMaps tab at the top of the page.
There you will see the maps on your satnav and you'll have the option to buy new maps.
When you're downloading the map be sure to download it to your computer and NOT your satnav. Otherwise you'll overwrite the map already on the satnav.
When it's downloaded click the windows START button and you'll find a folder called GARMIN. Click this and you'll find an item called MAPINSTALL. Use this to install the map to an SD card which you must have inserted into your satnav. It's best to use a 2Gb SD card not an SDHC. Again be sure you do not install the map to your satnav but to the memory card. You get the option of where the map will be installed during the set up process.
If you have not registered your satnav you can do so by going to www.garmin.com. Click on the drop-down arrow and select your country. Click on myGarmin and then on REGISTER YOUR GARMIN DEVICE. You'll be asked to create a username and password. Keep them safe as you'll need them anytime you need to update your maps or buy new ones.
There's more information on installing maps at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps if you need more help.
1helpful
Lost gps and then found 6 months later and cant remember password
To reset your ONE XL, use a straightened paper clip, or something similar, to push the reset button. The reset button is next to the memory card slot, on the bottom of your ONE XL. Then turn your ONE XL on it will be back to it's factory settings.
1helpful
Garmin nuvi 300 asking for pin number
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
10helpful
2answers
I lost the password and need to reset it. Please help.
I contacted Sharp Tech support who told me to:
Touch the reset button on the back of the unit. The display will show "RESET?"
Touch the 2nd tab on the front of the unit.
Touch ENTER
This will reset the unit to factory settings. All information will be lost, but you will be able to use the unit again. I did this and it worked beautifully.
Password
All you need to do is ask him where he was when he entered the password. Go to that location and power up the unit. It won't ask you for the password when you are at the location that it was entered. If you don't know the location, you will need to send the unit back to Garmon to be reset.
- Jim
1helpful
Secure mode
Secure mode is the anti theft function. Since you do not know what that is It suggests that you do not know the password. If that is the case then it seems like the unit is or has been stolen at one time. If you do not know the password then you have to bring the unit to a authorized Pioneer service center to have it reset. If the backup up sense wire is cut, or the system is disconnected from the vehicle, or if the reset button is pushed then the unit will ask for a password the next time it fires up.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
