Question about GE Profile JK915 Electric Single Oven
Ge profile oven lock button won't go off
Posted by Debra Strevel on
nayana sreekandan
  • 380 Answers
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Posted on Nov 22, 2011
    Kitchenaid superba oven
    GE PROFILE OVEN jckp18bw
    How to reset electronic
    Thanks
    Jul 03, 2013 | Ovens
    Ge oven jtp18 elements won't heat
    The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
    http://www.on-timeappliance.com/ovenrepair.html
    Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
    GE JT980 double oven door issue: I have a GE jt980 which I just bought from a cabinet company that used it as a display. It was never used, but when I picked it up, they had taken the upper door off, which...
    Make sure the oven door hinges are open fully and locked then reseat making sure the notch on the bottom of the hinges seats on the cabinet locating plate, then release the hinges and close the door....theese hinges can take your fingers off so be very careful
    Oct 11, 2017 | GE Profile JT980 Electric Double Oven
    I have a JT955 GE Profile 30"double oven...when the food is cooked, and I press "clear/Off", the oven won't shut off...continues to maintain temperature? Tonight, I had to shut it off,...
    Your wall oven has two main components that control the oven. The main control computer and the user interface. Your problem is probably in the user interface, although it could be the main control or both. I have had some success cleaning the ribbon that connects the user interface to the control with a little rubbing alcohol. That only works some of the time though. Due to the fact that the oven works except for the cancel button I would lean towards replacing the user interface if cleaning the ribbon dose not work.
    Aug 29, 2011 | GE Profile JK955SFSS Electric Double Oven
    Ge profile oven is in lock mode not able to turn it on , it says HOLD UNLOCK BUTTON FOR THREE SECONDS BUT THERE IS NO SUCH BUTTON, WHAT BUTTON SHOULD I HOLD DOWn?
    Hold the "lock" button for three seconds.
    This is the way mine works, yours is probably the same way.
    Holding the "lock" button for three seconds changes it from locked to unlocked and ALSO from locked to unlocked.
    Nov 16, 2009 | GE Profile JTP18 Electric Single Oven
    Hello I just bought the house and my GE oven door won;t close all the way in. Could you please help?
    there is a latch in the top of the door that locks in clean mode . need to get it out of clean mode
    Sep 03, 2009 | GE Profile JT912 Electric Single Oven
    GE True Temp Profile Oven, Locked Door Light stuck on
    there should be some type of button that the door hits to turn it on and off
    Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
    GE Profile JK915 Electric Single Oven Logo
    1,768 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Michael Thomas
    Michael Thomas
    Marvin
    Marvin
    Are you a GE Oven Expert? Answer questions, earn points and help others
