I think the remote Gould be shot I really like this projector it has been really good till now maybe I should try a new remote are they alive ? Can I still get one if any one can help I would appreciate it cheers
SOURCE: password problem to change setting for my Sony Cyber Shot camera
With the camera off hold the Zoom to the 'W' side. While holding the
zoom press the play button, when the camera powers on it will ask if you
want to reset. Press ok.
The camera will then ask you for a 4 digit reset code. The code is:
7669
Have fun!
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to
each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote.
If you do then the problem might not be the remote but the sensor on the set.
If you need a remote then try the following or other sites;
In the USA look at; www.remotes.com
In the UK look at; http://www.espares.co.uk
