Question about Kitchen Appliances - Others
Old 35lb fryer pilot turns off intermitantly - Kitchen Appliances - Others
Posted by robert blake on
Susan Bennett
    Scholar:
    New Friend:
  • 99 Answers
Could be a bad thermostat, or gas valve, either one....If either is bad, that could be an issue....As long as it lites ok, I would probably start with the thermostat...This is natural gas, correct? If it's electric, there could be other issues, but since you don't mention brand, gas or electric, it's hard to guess? I really need more info, but on electric models there is also a high limit switch, and if that goes bad, you could have this problem as well. Sometimes resetting that switch does the trick, but if it's gas....then I would try the thermostat first....
Susan
Restaurant Equipment Outlet
Cinc, OH
Posted on Nov 26, 2011
Pilot light won't turn off
Any parts been changed? valve might be wearing out.
Apr 23, 2013 | Imperial IFS40 Deep Fryer
I have an imperial fryer. Pilot is on but main burners don't ignite. Pilot looks normal & thermostat clicks when turned
Number 5 is your thermopile/pilot generator. It is a pilot generator that does 2 things. It holds open the valve with a safety magnet and it operates the safety valve solenoid whenever the control stat calls for heat. Overtime they get weak and will hold the pilot but not operate the valve solenoid. I would replace that pilot generator.thermopile and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 30, 2012 | Imperial IFS40 Deep Fryer
Put a new valve in a imperial fryer pilot lights and stays lit but when i turn the t-stat on it shuts off
The reason is the pilot generator will hold the safety magnet but it won't operate the solenoid.
It is old and weak.Ain't putting out enough power to operate the solenoid. Get a new generator
Jul 16, 2011 | Imperial IFS40 Deep Fryer
Pilot light goes out
Two things to check. Make sure you have continuity through the terminals on the high limit. Also make sure you have a good pilot flame and the pilot generator is supplying over 500 millivolts. It's either the high limit or the generator.
Tom
Jul 15, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot won't lite. fryer is 6 months old. Did get pilot to lite once and as soon as we turned thermostat pilot went out.
When you turned on the thermostat you required more millivolts from the system and it failed. Low millivolts. That would tell you the pilot generator needs replacing. Make sure you have a good pilot flame hitting the pilot generator.
Tom
Jul 07, 2010 | Vulcan EF3 Deep Fryer
Pilot goes out when you turn up thermstat
The thermocouple, the part that is heated from pilot light and produce small electricity and is connected to the gas valve, is a small copper pipe wire, need to be replace since it can not enough electricity so to keep the electromagent on valve on when you try to turn up and the gas coming out from the burner is blowing out the pilot light.
So the most posible reason is to replace the thermocouple which is the cheapest part. Their is a very small chance that the gas valve is faulty but this depents how old the fryer is and how much have been work.
May 09, 2010 | Imperial IFS40 Deep Fryer
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
Feb 22, 2010 | Pitco Frialator SG14 Deep Fryer
Vulcan Deep Fryer Need to Light Pilot
you have to hold the knob in after pilot is lit for at least one minute
Jul 09, 2008 | Vulcan EF3 Deep Fryer
Kitchen Appliances - Others Logo
60 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
