Hitachi 51UWX20B 51" Rear Projection Television Logo
michael pomory Posted on Nov 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Set 51uwx20b, how do i fix magic flash to reset factory settings
There are ghosts in picture and blue and green colors are not in focus. magic focus will not reset to factory settings. cannot reset by manual convergence adjustment. what can i do to correct this problem?
Anonymous
Level 3:
  • Master 616 Answers
  • Posted on Nov 22, 2011
Anonymous
Master
Level 3:
Answers
616
Questions
0
Helped
144783
Points
1638
Convergence board needs repair, google you model # and see if you can purchase a repair kit.
How do i fix double image and green and blue seperation
Typically it is fairly easy to determine weather you need to do a convergence repair or just make an adjustment with your TV's original remote. Take a look at this youtube video to find out which problem you have...
2answers
Colors are out of focus and magic focus wont fix
If you have tried the customer convergence menu/control and can not set the convergence you have a fault with the electronic circuit that controls the convergence of your 3 picture tubes this overlaps the 3 colors red, green, blue to create the proper color combination's of colors for a proper picture
3helpful
HITACHI 57UWX20B has blue ghost shadows how do I
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
1helpful
Color is distorted. Green, red, and blue ghosts
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
2answers
How do I adjust the HD quality for a crisper picture? I have tried Magic Focus, but need to know where the sharpness or contrast can be tweeked .
The magic focus function is to electronically align the red, green and blue beams. So all it can cure is colored ghosts. The contrast, brightness and sharpness adjustments are in the customer menu settings. With the remote just push menu and select video or picture adjustments. Those adjustments are in there.
1helpful
Green & Blue Ghosting Convergance problem
Odds are real good that the cooling fluid in the green and blue picture tube assemblies has become contaminated. You can tell by looking down into the lenses with a flash light. Funny thing is the red never gets contaminated because whatever organism is causing the problem can't survive in red light. BTW this may still not solve all of your convergence problems but when the colors are so badly diffused the convergence sensors for flash focus can't lock onto the beam landing.
Panasonic projection tv
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Double image/ out of focus with green and blue seperation
Your tv is crt-based and is out of convergence. In other words, the settings for keeping the Red, Green and Blue images aligned have drifted and must be reset. This is common with CRT projectors and CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Hitachi 61SDX picture got dim shows Code 3
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
