Question about GE WBXR2090B Top Load Washer
How old is my GE washer WBXR2090B2WW - GE WBXR2090B Top Load Washer
Posted by Sue W on
Do I keep my old Kitchenaid extra capacity or keep the new GE GTWP1000
The GE has a capacity of 3.3 cubic feet. You did not list the model of the kitchenaid. Make sure the GE was stored correctly because if it might have lost oil or gotten brittle belts or gaskets. Also it might have frozen.
Feb 22, 2014 | Washing Machines
1+ year old GE wjre555ok2ww washer won't release the wash water during spinning. How can I fix that?
Small things get into the electric pump. I removed coins and shoestrings from the pump in the past. They are easy to take apart and clean up. Rarely do they fail.
I have a video and service manual for your Hydrowave Machine HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 04, 2011 | GE WJRR4170BT
Have a 6 mounth old top loader washer GE and the spin will not work
A six month old washer should be under warranty. Did you register the product and do you have your receipt? I would call the place where you purchased it first and see what they have to say.
Dec 16, 2010 | GE WBSR3140DW Top Load Washer
Installed new control asm on ge washer wbse3120b now all the lights are flashing and no power?
On you old control there was a plug with just a jumper wire. This is the model select plug. Without this plug the washer does not "know" what model it is on and the lights will flash. http://www.appliance-repair-it.com/ge-washer-lights-blink-after-replacing-the-control-board.html
Sep 13, 2010 | GE WBSE3120B Top Load Washer
How old is my washer? When were these made?
You need a serial number to tell for sure.
They probably stopped making those a few years ago.
And the oldest one I've seen it about 10 years old. So probably between 2-10 years old.
GE washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | GE WJSE4150B Top Load Washer
My GE Model # WBB4500E1WW washer not spinning
the washer is on but not spining and the machine is about 6 month old
Dec 19, 2009 | GE WBB4500EWW Top Load Washer
Oil on floor under washer
Oil is generally not a good sign. It means that the tranny seal is blown OR it means that the tub seal is bad which allows water to enter the tranny (water is heavier than oil... if water gets into the tranny it will displace the oil and force the oil out)
This being a GE? I'd wager that a tranny job is in order. If the machine is less than 5 years old it's under warranty so you'd call GE at 1-800-GE CARES. If it's more than 5 years old? Your washer is no more than a boat anchor. Get a new washer, preferably a Whirlpool. The repair cost for a new tranny will out-weigh the value of the machine.
Hope this helps.
Mar 23, 2008 | Kenmore 22642 Top Load Washer
How do I open my GE Top Load Washer to check for leak
Pull the washer foward, tilt back against the wall and look under it.... look where the water pump connects to the motor shaft... check for rust etc.... if so replace pump....
Dec 15, 2007 | GE WCXR1070A
GE WBXR2090B Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
