Question about OKI C5200n Laser Printer
How do i clean the print heads on a oki c5200
Posted by paul freeman on
nayana sreekandan
  • 380 Answers
With the top cover open, gently wipe the LED head(s) with the lens cleaner pad supplied with replacement toner cartridges. A soft, lint-free cloth with some isopropyl alcohol (rubbing alcohol)** can also be used.As the last step before closing the cover when replacing a toner cartridge or an image drum.
If you are experience poor print quality, including
- longitudinal white stripes or fading
- blurred letter edges
CAUTION! Do not use methyl alcohol or other solvents on the LED heads: this will damage the lens surface.
Posted on Nov 21, 2011
Why can't I use a toner and drum set from an OKI c5250 in an OKI c5200
While the drum units may appear the same, chances are Okidata puts a different chip on it that makes in incompatible. The C5200 will use drums from a C5150. The C5250 appears to use different supplies.
Sep 14, 2014 | OKI C5250n Printer
Why does yellow not print on oki c5200?
The fountain under the yellow cartridge could be dried and clogged (assuming the cartridge is not dried up from too infrequent use and is not empty. If you stuff all around the fountain with rags and then gently force water into the fountain using a syringe you might be able to clear the ink passageway and restore yellow in the machine. Servicing the other fountains might be in order, too, since one clog is likely to be followed by others. Remember to use the printer more often to prevent such cloggingg. Also, you could try the built-in printer head clean function before trying the manual cleaning; but, generally, when it gets to the point of zero ink delivery, it's already to late to clear the ink clog with fresh ink, which is what the self clean feature does to try to dissolve the clog and restore ink flow to the fountain.
Aug 19, 2014 | OKI C5200n Laser Printer
Oki c5200 alignment
often a drum unit will go bad causing misalignment of just one color. print the demo page and that will help you diagnose what one of the 4 colors is off and replace only that one drum unit
Jul 01, 2014 | OKI C5200 Color Laser Printer
My oki data C5200 in printing a faded picture along the right side of the page only. I have cleaned the print heads and checked the levels in the cartridges. Everything seems to be fine. Can you help?
> OKI C5200n laser printer
Take the toner-cartridge out, and gently tilt it left-and-right
to redistribute the remaining toner in the cartridge.
Reinstall it.
Oct 13, 2010 | OKI C5200n Laser Printer
Oki data c5200. When printing color there are streaks where it looks as though something is scraping the toner or page so to speak.
Could be 2 differents problems.
1st you can clean the leds.
2nd you can change the drum of the color problem,
Aug 18, 2010 | OKI C5200n Laser Printer
Oki c5200 paper jam
I used tweezers after I took every thing that could come out--out.
Feb 19, 2009 | OKI C5200n Laser Printer
Oki c5200 prints double on page
Sounds like the fusing unit needs to be replaced.
Nov 17, 2008 | OKI C5200n Laser Printer
OKI C5200 - Faded black print area
Trying cleaning the black LED's that are on the top portion of the open clamshell. Use rubbing alcohol on a rag and wipe each bar x4/. These units charge the drum surface where print is going. This should work.
Jun 12, 2008 | Samsung OKIDATA - OKI C5200n - Printer
Oki c5200 printer driver for MAC
I also need a driver for my Oki C5200 laser and Mac with OS X Leopard. HELP.
Apr 17, 2008 | OKI C5200n Laser Printer
OKI C5200
Just a thought for others... is this an image drum problem?
Also, if you haven't done this yet - try gently shaking the toner cartridges to redistribute the toner. Just make sure you do it gently and over a newspaper or rugs in case some toner spills. One last idea - turn off the printer and turn back on after a few minutes?
Jan 02, 2008 | OKI C5200n Laser Printer
OKI C5200n Laser Printer Logo
236 people viewed this question
Top OKI Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
