Question about Acer Aspire One PC Notebook
Acer aspire 5935g battery problem
My battery doesnt seem to be charging when plugged in although it says it is. It happened last night and then hour later looked and it had charged up to 75%.
    Novelist:
  • 111 Answers
Many users do not use their notebook/notebook batteries correctly. The battery in a laptop/notebook/netbook is a rechargeable battery, like the battery in a Cellphone, a Digital Camera an eReader or an MP3/MP4/MP5 Player. This type of battery needs to both charge and discharge, if it is to perform to its maximum capacity and have a full, long life.
You would never dream of using a Cellphone, Digital Camera, an eReader or an MP3/MP4/MP5 Player only with the devices permanently connected to the mains electricity, because they are all devices that are designed to be used while the user is moving around whether indoors or outdoors, powered by their rechargeable batteries. the batteries of such devices are only recharged when the charge in their cells is depleted and then only for as long as it takes to restore full charge to them.
As with the other devices mentioned, a laptop/notebook/netbook's battery is designed for mobile use and the user should charge it to 100% full and then stop charging it to then use the device on battery power alone, until the battery is low on power, when the recharging cycle can then be repeated.
A notebook/netbook has more flexibility than the other devices mentioned because, unlike the other devices, it can also be powered directly from the mains electricity, without the battery installed.
If your laptop/notebook/netbook is mainly used away from the home or office, it is fine to leave the battery permanently installed. If, however, it is mainly used indoors at home or at work and always or almost always on exactly the same desk or table, then it makes little sense to use it either on battery power alone or with the battery permanently installed.
Charge the battery up to full charge and then disconnect the battery from the device and keep it safely for when you next need to use the laptop/notebook/netbook on the move (if the battery is stored for long periods it may require additional recharging to both maintain the battery's condition and to keep it fully charged because low level power dissipation takes place in a disconnected battery). Then connect the device to the mains electricity without the battery and continue using it like that.
If the laptop/notebook/netbook is mainly used in a single permanent indoor location, then charging has to stop when the battery has reached 100% full charge and should only be resumed when the device gives a low battery charge warning.
It is also important not to let rechargeable batteries drain completely by ignoring the low battery charge warming and continuing to use the device until the battery runs out of charge and the device powers down suddenly. Sudden shutdowns like this are neither good for the battery nor the device and can shorten the lifespan of both.
Continuing to charge any rechargeable battery when it has already been fully charged damages and shortens the life of the battery. It can even damage the internal Power Management System of the device if done over a sustained period of time and/or for prolonged periods of time.
When your notebook only shows 75% as the maximum charging level, this is an indication that one or more (probably two) of the individual cells that make up the battery are fully depleted, damaged and probably no longer capable of storing a charge, for the reasons given above. You should stop charging this battery after it has reached 75%, otherwise more cells are likely to become damaged and so on until the entire battery is dead, unresponsive and useless.
Posted on Nov 20, 2011
How long should I charge Eclipse 180Pro 4GB mp3 player?
i looked up reviews and a lot of people are complaining about no battery life they charge it overnight and it might last 4-5 hours and they cant't get it to charge on a laptop I suggest plug it into a USB wall plug if you have one and see if that gives it more life
Jan 18, 2016 | Eclipse Audio Players & Recorders
Tip
Make your Lithium Laptop Battery last longer.
Hello folks,
Although I usually offer advice on backing up files or recovering them, I have been asked a lot lately how my 3 year old laptop still runs 1:45mins on a standard battery when many peoples 1-2 year old laptops can barely last an hour.
Simply put, most people do one of two things wrong. Both are common misconceptions and easy to remedy. First I've heard countless people tell me they pop the battery out of their laptop and toss it in the desk drawer until needed, often months. Second I have been told by more people than I can count that they leave their laptop plugged in 24/7 for most of the year.
Bottom line, although popping it out and leaving it in the drawer is less harmful to it's lifespan, both ideas are wrong.
The shelf life of most unused lithium batteries is shorter when unused than ones being used properly. The lifespan of a battery that is constantly being trickle charged is even shorter.
Most batteries in modern laptops are 4-6 cells, designed to give about 2 hours of charge and should last 3-5 years with charge life starting to degrade in the third year.
A "stored battery" has only 3 years of shelf life due to extended times sitting discharged and one that is trickle charged 24/7 may burn out in as little as a year.
Many laptop manufacturers have taken measures to improve this but ultimately the best thing for your battery is to use it. If you currently run you laptop plugged in 24/7, unplug it every night after you shut it off, then when you start it in the morning, let it run an hour before plugging it back in. This will give the battery both down time and exercise.
If your battery is in a drawer somewhere for safe keeping, put it back in the laptop, run it down then charge it over night and run it down then recharge it one more time. Store it back in the drawer charged and repeat the cycle at least once a month.
These tips will help drastically improve you batteries performance over time. My 3 year old laptop only ever got 2 hours of battery life and still gets 1:45 with no power saving measures, give it a try.
Crankstart
on Mar 20, 2010 | Computers & Internet
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
Doesnt charge or start
First remove charge it check voltage, then 12 hours later see if 12-13 volts. Also check start fuse.
Mar 23, 2014 | Craftsman Garden
Samsung Alias will not charge.
try with another battery. if it charge you have battery problem. if it doesnt you have motherboard problem with phone
May 30, 2009 | Samsung SCH-u740 Cellular Phone
Phone won't charge or turn on
Try removing the battery and clean the contact's, then reinsert the battery and let it charge, if it do'es not begin to charge your adapter may need to be replaced, or your battery.
Apr 06, 2009 | Lands Phones
Ipod will fully charge but only lasts a short time. whats wrong?
My little brother gave me his ipod shuffle for the same reason, saying the battery was dying and would only play for half an hour after a full night's charge. However, I went ahead and gave it a shot anyway and it always lasts for several hours (long enough that it's never died, so I don't know an actual time).
Anyway, it turned out to be a usb hardware problem. His old computer wasn't built to charge via usb, so the ipod would take what little it could and flop five songs later. I don't know what kind of hardware you're running, but perhaps you could try plugging it into a different computer and seeing if that chnges things?
I would also recommend looking into wall chargers, if that is the case. Otherwise the convenience factor kinda goes out the window.
[email protected]
Mar 28, 2009 | Apple iPod nano
CREATIVE ZEN GONE HAYWIRE
sounds like it might be either a bad firmware driver, which can be erased and reinstalled via the USB connection to your computer and a download from creative. Or the battery has gone bad, in which case you have to have it sent to creative for Repair.
Jun 29, 2008 | Creative Labs ZEN Vision:M Digital Media...
Acer Aspire One  PC Notebook Logo
187 people viewed this question
Ekse
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
