A500 Polaroid
SOURCE: Time & date
What could be happening is the you mother board is bad already. Usually digital cameras like computers use a button cell battery inside to keep the bios in memory or the board uses the installed batteries to keep the bios in memory but at a very slow power consuption rate. Everything comes down to pretty much a bad circuit somewhere that is causing memory lost and high consuption of battery power.
Also i've noticed that a lot of people with this camera is having the same problem. This called be because of mass production you all could have a bad batch. Meaning your cameras came off the assembly line around the same time.
SOURCE: cant take picture. polaroid a500 camera reads sd protected.
It means the sd card cant be accessed unless you remove the protection . Connect sd to laptop and use software to remove the protection .
SOURCE: broken screen
well it could be replaced but to be honest you would be better off buying a new one it would cost you more to fix it than to buy a new one just like it
SOURCE: I had a polaroid A500 Digital camera given to me,
my camera works fine but the pictures i take are very bright i can not get it to dim
SOURCE: dont know how to turn
Hi onestoppa972, I could try and explain it to you, but I think it would be better for you if you were to read it and have the pictures for reference. If you don't have the manual, you can download it here: http://safemanuals.com/user-guide-instructions-owner-manual/POLAROID/A500-_E Just follow the instructions and download it for free and it shows the various flash settings. If I can help you further, please let me know. Thanks.
Jeff
