Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
How do i fix my sony grand wega tv kf60xbr800 with 6 blinking lights
Posted by darren job on
DAVE FONSECA
    New Friend:
  • 3 Answers
Replace Projection Lamp/Bulb A1601-753A (XL-2000U) THIS ONE IS ON THE RIGHT FRONT COVER REMOVE THE COVER BY PULLING OUT THE LIGHT IS RIGHT THERE YOU NEED TO REMOVE 2 SCREWS Replacement Projection Lamp/Bulb A1601-753A (XL-2000U)
Posted on Nov 23, 2011
How do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking...
Good day!!!
6 blinks its the clear indication that you have bad power supply board..
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Nov 20, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
Projection tv is about 7 years old. I am getting no picture. when I turn it on the red light just blinks and no picture no sound. the tv just will not power up. I unplugged to reboot. did not work. Is...
If this is a Sony Grand Wega, call Sony, complain, and Sony will give you an option to get a brand new for a very small amount of money instead of fixing the one you have due a class action, if you qualify.
Apr 13, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My sony grand wegas will not turn on no picture no sound .
Most possible cause would be broken/ dead lamp in your Sony grand wega tv. Check and replace lamp if it has not been replaced in last 2-3 years.
Do you see lamp red light on tv front or its power light is blinking? Let me know to provide you more info.
Thanks.
Jun 12, 2010 | Sony Grand WEGA KF50SX300 50" Television
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Grand Wega- Red light Blinking
I would have to say you have a bad projection lamp!! They do NOT last forever!!! About 3000 hours is normal. If this is out of warranty--about $300 in--house repair or so.
Oct 09, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blinking Red Light-50" Sony Grand Wega
It sounds like Lamp is broken in TV and requires replacement.
How old is this TV and did you replaced lamp recently?
Oct 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony grand wega KF60DX100 Won't Power on
THE RED LIGHT THAT BLINKS IS IT THE LAMP BOX THAT THE RED LIGHT BLINKS IN OR THE STAND BY LIGHT THAT BLINKS ? IF ITS THE LAMP BOX THAT BLINKS THEN YOUR LAMP HAS BLOWN AND NEEDS REPLACED YOU CAN FIND THE PART # FOR YOUR T.V. FOR A NEW OR REFURBISHED LIGHT IN YOUR OPERATING MANUAL AND WITH THE PART # BUY A NEW ONE OFF EBAY,ALSO YOUR OWNERS MANUAL WILL GIVE YOU STEP BY STEP INSTRUCTIONS ON HOW TO REPLACE IT AS THIS IS A COMMON PROBLEM WITH PROJECTION T.V.'S IF ITS THE STAND BY LIGHT THAT BLINKS I NEED TO KNOW HOW MANY TIMES IT BLINKS AS THAT'S A SELF DIAGNOSTICS CODE THAT YOUR T.V. IS GIVING FOR THE PROBLEM AND FOR SONY THERESE NO CODE FOR 1 BLINK OF THE STAND BY LIGHT.
Mar 16, 2009 | Sony Grand WEGA KF60DX100 60" Rear...
My sony wega tv is not staying on it turns off when the standy by light turns on
do you get a blinking light if how many times does it blink the pause then blink?
Feb 07, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
