Question about Alpine iXA-W404
Setting time on Alpine iXA-w404
Am trying to set the time on this system but somehow I am failing. Every time I press the setup button only audio setup option appears. Please help
Posted by Ras Tee on
Felipe Martinez
    New Friend:
You can reset your tr7 if you don’t have one go through unlocking functions with the parking brake
Posted on Nov 12, 2017
Jeffrey Turcotte
  • 8,984 Answers
Are you holding the setup button down for at least 2 seconds? Then using the >> to switch items for setup? If you don't have the manual, download it here and flip to page 20:
http://support.alpine-usa.com/products/documents/OM%20iXA-W404_EN.pdf
Posted on Nov 21, 2011
Wiring instructions for PAC Tr7 video bypass, for ixa-w407
Hello! go here for instructions....http://assets.sonicelectronix.com/manuals/pac/tr7.pdf
Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jan 18, 2012 | PAC Audio Pac Tr7 Tr-7 Video Lock Bypass...
Cant change the time on my ixa-w404
Ok it sounds like your stuck in the audio menu function. The way to fix this is by going to your alpine and unplugging your tr7 if you have one with the ignition engaged unplug tr7 then plug it in press setup for 3 second and your other setup options should be listed.ok if you don't have a tr7 bypass go through the parking brake unlock function. Set brake with brake pedal depressed release parking brake then pedal. Press parking brake then power unit and check setup.
Jul 29, 2011 | Alpine iXA-W404
Cant set the time
What you need to do is buy a PAC TR7 universal trigger module.Without this module you have to do some sequence of events with your brake and parking brake.and it wont let you program the unit. By default the TR7 is pre programmed for the video bypass. Even if you don't have any kind of video in your system you need this TR7 setup to program your IXA W407.
Nov 22, 2010 | Alpine iXA-W404
I had my alpine ixa-w404 installed but when i turn off the car all the presets and settings disappear and it returns to the default. The deck is also off when i restart the car. i ahve to turn it back on...
Your Yellow (constant battery) wire is not properly hooked up. The yellow wire is what keeps power to your unit while the car is off so that it keeps all the memory. I would start by checking to see if that wire is connected right and if so, start to trace it back from there. Hope this helps and good luck!
Aug 04, 2010 | Alpine iXA-W404
HOOKED YELLOWBLUE WIRE TO BRAKE WIRE STILL UNABLE TO SET CLOCK AND OTHER FUNCTIONS
WHY would you connect it to the brake wire???
You likely want to connect to 100% power from the battery. It should be fused however. Find where the clock in the car was/is powered and connect it to that.
Mar 20, 2010 | Alpine iXA-W404
Bypassing the ebrake-grounding doesn't work on Alpine-iXA-W404
Found the solution
Either get a pair of toggle switches to simulate the Foot Brake and Parking Brake OR get a product (from PAC) that simulates it for you.
Aug 22, 2009 | Alpine Car Audio & Video
Bypass iXA-W404
The 404 requires multiple signals from two separate wires to turn off the video block. Simply grounding one wire will not work. There are bypass modules that will send these signals to the head unit available on ebay. Just search alpine 404 bypass. Your other option is to use two toggle switches to simulate the parking brake and foot brake signals necessary to disable the video block.
Jul 08, 2009 | Car Audio & Video
Alpine IXA-W404 how do i can't get video to play. I didn't connect the hand brake wire and the footbrake wire, would that be the cause and if so how do I get past it??
You need to connect the yellow/black wire to the brake switch and the yellow/blue wire to the ground wire on the hand brake. After that you have to go through the task of holding down the foot brake, pull the hand brake, release the hand brake, pull the hand brand then release the foot brake.
after all that then you can watch your video. You will want to connect those wires so you can setup your system.
Jun 07, 2009 | Alpine Car Audio & Video
Alpine iXA-W404 Logo
1,252 people viewed this question
Top Alpine Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
