I guess you need some electronic testers that most probably you don't have because assume you are not a computer tech. Should you have another laptop of similar characteristics, you could test the charger else I see no other option but visit the computer shop where you bought your new charger and get them verify the device as part of warranty
The best way to email any document from any printer is to have a scanning program that can scan from your printer/scan/copy machine. If your printer only has printing capabilites then it is impossible to capture the printed document back to your laptop.
The first step is to check to see if your Xerox copy machine is a model that includes printing/scanning/copying capabilites.
If it does, then install the scanning program.
Once installed, scan your document, save it to a place you remember on you laptop, then email it using your favorite email program, such as hotmail or yahoo.
First, you need to make sure your power adapter is providing enough
power to both run the laptop & charge the battery. A very good way
to do this is to compare your laptop voltage & ampere requirements
(written on a sticker on the bottom of the laptop) with the voltage
& ampere ratings of the power adapter. Voltages should be the same,
or the power adapter's voltage about up to 0.5 volts more than the
laptop's voltage rating. Amperage of the power adapter should be at
least equal to or greater than the laptop's rating. It should never be
less than the laptop's rating, or else the power adapter will be
providing insufficient amperes to charge the battery. Of course, the
power adapter's nominal amperage might be ok, but it degraded on usage.
You can verify this by testing using a good or new power adapter. If
the battery did not charge using the new power adapter, take the battery
off the laptop, & using a dry tooth brush, scrub in between the
fins of the battery connector on the motherboard & on the battery it
self, then put the battery back into the laptop & try again. If
this still did not resolve the problem, then the battery itself could be
bad. Try it on another laptop, or try a good or new battery in your
laptop. If this did not work, there might be a possibility that the
charging circuitry on the laptop's motherboard is defective & needs
servicing. In order to do this, the laptop needs to be disassembled
& the motherboard checked for defective/burned out components in the
area near the DC jack. Any defective/burned out components found should
be replaced, or you might need to replace the laptop's motherboard
altogether.
i need to connect my ipod docking device to my laptop in order listed my music from the laptop louder throygh the device.
i bought a usb cable in order to connect the lap top to the jbl device ?
It seems that your battery is dead [ Lifetime ended] . What
you need , is to replace it . Just replace the battery with a new
one ] and problem will be solved .
I had that and one of my ram modules was finished. Take it apart as much as you can and check everything is firmly in place. you can get new ram but it may not be ram it could be anything loose cable failure is the clue. As laptopps get bounced a lot you could well be lucky. Remove battery and power and take your jewelry off I use disposable gloves so I dont cause any shorts. While you are in there give your fan a clean. good luck.
if you want to use wireless connection you have to have a wireless router, and you connect your internet cable into the router, so after you can have a wireless connection with your laptop and his wireless card, and you can work with your laptop everywhere in your house.
you can buy a wireless router in every computer shop.
last thing if you have a desktop PC you can connect a new internet cable to the wireless router (type RJ45)
I hope this helps Please rate accordingly Thank You sserpentio
