Question about GE MiniCam Pro HO98067 Webcam
Minicam pro 98083
Haw to install it
Posted by Boris on
5 Related Answers
Anonymous
SOURCE: GE MiniCam Pro HO98756 Webcam wont install w/ Vista
hola nenas
Posted on Sep 17, 2008
Pawel
  • 41 Answers
SOURCE: i lost the installation cd the GE MiniCam Pro
Got to Jasco website and download all the drivers you need
Posted on Mar 15, 2009
Anonymous
  • 1226 Answers
HELLO,
be sure that the unit is working or compatible in vista OS. ELSE you need to download and intall the drivers for vista.
Go to the manufacutrers wesite for update or search driver here: www.driverguide.com
melnavz
Posted on Jun 04, 2008
micky dee
  • 3015 Answers
SOURCE: MiniCam Pro HO98756 Webcam: I have a GE Minicam Pro 98756 that won't connect t...
Before you can use your webcam in any chat program you have to configure it to that program
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Posted on May 06, 2010
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: MiniCam Pro HO98067 Webcam: i need the software for install minicam pro 98067...
Copy this site and paste it in your web browser and hit ENTER to download GE Mini Webcam Drivers
http://www.jascoproducts.com/support/software-downloads.asp
Then do this:
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
Posted on May 23, 2010
Minicam pro 98756. windows 7. installed driver and have sound but no video. reinstalled driver and checked all connections. cam works on other computer with windows vista. have gone on line for any...
I had the same exact problem. The correct driver for the minicam pro 98756 version 2 are not found anywhere online.
However, the
98083 Minicam Pro driver will work with Minicam Pro 98756 version 2. I have just tried it out myself.
Here is a direct link http://www.jascoproducts.com/support/download-files/98083.zip
Feb 05, 2011 | GE MiniCam Pro HO98656 Webcam
How can i install the minicam pro into my inspiron 2200 laptop?
Hi fgdavidjr,
1. Download the latest webcam driver here:
2. go to the PC CAMS section then click the "ZIP" for 98067 Minicamâ„¢ Pro
3. download the driver install it then restart your computer
Hope it helps,
Thank you for using Fixya
Best regard,
Reyjoshua07
Jan 21, 2011 | GE MiniCam Pro HO98067 Webcam
My mini webcam pro 98083 gives me a lisp tongue when i record and now it's not even working. how do i fix it?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 25, 2010 | GE MiniCam Pro HO98067 Webcam
I lost the installation cd the GE MiniCam Pro
Mar 15, 2009 | GE MiniCam Pro HO98067 Webcam
MiniCam Pro 98067 help
I
lost the cd instalation for my minicam(pro) Model#98067
How can I install de cam in de pc?
Oct 23, 2008 | GE MiniCam Pro HO98067 Webcam
TENGO UN MODELO QUE ES HO 98657 Y NO LO PUEDO INSTALAR EN VISTA
Apr 30, 2008 | GE MiniCam Pro HO98756 Webcam
Minicam pro ho98756
here you can find your driver program and manual.
Sergio
http://jascoproducts.com/support/software-downloads.asp
Mar 13, 2008 | GE MiniCam Pro HO98756 Webcam
GE MiniCam Pro HO98067 Webcam Logo
87 people viewed this question
Top GE Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
