Question about Ovens
Have problem with Maytag CWE 9000 the beeper keeps going off even after you press cancel Code is F1, any idea
Posted by Will Givens on
Rick Ead
  • 1,998 Answers
Likely the problem is a bad control board, aka a clock/timer. Usually F1 error codes do refer to main board or main control error in which you would have to replace the control. You can also try shutting off the breaker for 7 minutes which sometimes does make the control reset but this only works maybe 10 percent of the time due to the F1 error code. If you need the part number of the control message me back your full model number and serial number as well.
Thank you
Rick
Posted on Nov 19, 2011
My maytag super capacity plus won't unlock after
this would be the best source look at link i hope it help out
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjhpKi-i5TXAhVmyoMKHX_OAtMQFggnMAA&url=http%3A%2F%2Fproducthelp.maytag.com%2FCooking%2FWall_Ovens_and_Ranges%2FOven_Product_Assistance%2FHow_to_open_a_locked_oven_door&usg=AOvVaw3VNunJSAkZGld_PY0xGM3s
Oct 28, 2017 | Maytag Ovens
My top oven shows F1 and keeps beeping what is wrong?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
Aug 18, 2011 | Frigidaire PLEB30T8A Electric Double Oven
I keep getting a F6E5 error code on my Whirlpool stove. I have tried unplugging it (overnight) and the error won't go away. Any ideas before I call the repair man?
The error code F6E5 means "Cancel key error". Press the "Cancel" and "Start" keys in the following order: CANCEL, CANCEL, START. Verify the error code displayed on the control by observing for longer then 1 minute. If the error comes back then the control board needs to be replaced..
If this was helpful please rate me Thanks
Jun 12, 2011 | Whirlpool Ovens
When my oven almost reaches the temp during preheating, an alarm sounds and I recieve an error code F 1-2... The tech support line for Maytag(now Wirlpool)had no idea what this means and advised me to...
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
never heard of an F1-2 code but they make new stuff everyday. Go to this link to get tech data: Maytag library of manuals
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 19, 2010 | Ovens
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
Maytag oven shuts off?
Hi. This is a possible touch pad, or EOC(Electronic Oven Control Board) failure code. The test below will help isolate the issue.
This simple test will help determine whether the EOC (Electronic Oven Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the EOC as a single assembly, in which case this test is not necessary. Simply replace the EOC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 20, 2009 | Maytag MEW5530D Electric Single Oven
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
What does the F1 alert mean?
Hello jiverson,
Welcome,
You said, your get a recurring F1 beep even after I press "cancel" I worked with the oven for about 2 hours trying various combos of opening the oven, pressing cancel and trying to perform various functions (light, clean, bake, broil, etc.) to no avail. I got it to stop for about an hour at one point, but it started right back up again. It also seems that every now and then the oven light will come on all by itself during one fo these alerts
Please send me your complete model number including the single diget at the end of the model number.
For example: FGB24S5AW1
Then I can be sure!!!!!!!!!!!
Waiting your response. I'll check for it through out the day!
And get back to you as fats as possible so you can take care of it Monday!
Huuum
In some ovens It could be failure of your, EOC (Electronic Oven Control) failure
Oct 19, 2008 | Frigidaire FGB24S5A Gas Single Oven
Error code F1
I had the same problem and found this post:
http://fixitnow.com/wp/2006/03/11/maytag-amana-jenn-air-and-magic-chef-range-f1-codes/
The oven had been cleaned earlier in the day and the touch pad ribbon connector was shorting. I cleaned it with rubbing alchohol and blow dried the whole board for good measure. Hooked everything back up and haven't had a problem since.
Jun 08, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
126 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
john h
Are you an Oven Expert? Answer questions, earn points and help others
