Pioneer DEH-1100 CD Player Logo
A
Anonymous Posted on Nov 18, 2011
When i tayking security code to my Eurovox overhead DVD/Screen combo unit
Eurovox 2207
My battery went flat and I jump started my car (Holden VT) now my stereo is locked. Dose anybody know how to unlock it. It's a eurovox radio unit.
Samantha, You need the VIN and the radio serial number. Take those into a Holden dealer to get the radio code and programming instructions from the dealer. They may want a small fee for the #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/131983-vt-stock-radio-cassette-player-security-code.html
Radio Security code Street Commodores Online Forum
Go Technologies Eurovox FAQs
Security code for eurovox car radio
i full out the eurovox car radio of a holden barina 1995,when turn it back it required a security code..anyone can help me have the code..?
thank you...
2helpful
I have a 2003 suburban.my radio didnt work.i bought anither same model radio from ebay. when i put it on it says locked. need help. how to unlock this radio. thanks
If it is a Eurovox brand you need the pin code. If you dont have the pin code you need the serial number of the unit and you can get the code from a company called Go Technologies via the www.eurovox.com.au webisite. This costs a small fee and the application form can be downloaded from the website.
If it is a Eurovox radio you can enter 1111 if the code is a 4 number pin of 111111 if the code is the 6 number pin. This will put the unit into test operation for about 3 minutes to at least see if the unit works. While in this mode the screen will blink continually.
4helpful
3answers
37helpful
10answers
Hi i need a code for the euovox max. im in dublin
5a 01
00 aa b7 d1 d9 ce 8e 83 af
01 a3 eb ec 07 d6 49 d2 eb
2answers
EUROVOX MAX V - North East /Mbro
ok try this to sory your problem out. Press menu, 1570 , on nagravision screen is EMU set to ON ?
press ok , code screen make sure this is in box . Provider ID NTL 5401,
key 0. 3F B8 36 62 72 E5 E2 76
key 1. 35 5E D6 40 6E AA 99 41
should work fine now .good luck.
3answers
How to enter codes into Eurovox EX5000
press Menu.
1570
Nagravision. OK
00 enter new codes saving each code.
01 enter new codes saving each code.
exit out .
Code screen
You need to update the firmware. Start by clicking here: Then look in the eurovox folder in eamos library, then look in the eurovox pvr folder. Should help.
Eurovox Security Code Error
what does it mean when slot 0 card in and slot 0 card out comes up when you are watching tv
5helpful
3answers
Car radio pin code
Hi pat... bad news I'm afraid. You need to get the code from Eurovox. There is a way to change/defeat the code, but it involves having the thing apart on the bench and actually fitting a new memory chip to the radio that does not have a code. I used to do this if someone left a unit for repair and we were not left the code. I have cut and pasted the FAQ from Eurovox's site for you, Click the link to their code request form. There are also instructions on how to enter the code
And as always, the bastards charge for the info. Sorry I couldnt actually give you a code. I used to have charge $60 to recode a radio back in the day by rechipping it.
Why is my radio not working after the battery was disconnected/replaced?
The radio requires a security code to be entered. (also known as PIN number). A security code is either 4 or 6 numbers long for most of Eurovox Units.
How can I obtain my security code?
Download the Security Code Request form located in the Downloads section. Fill it out and send it in via fax or email with proof and payment. The serial number & model number of the piece of Eurovox equipment is essential. A new security code card will then be mailed to you and your details will be registered in our database.
Why does Eurovox charge for supplying a security code?
Security and administrative reasons. We enter your details in our database so if you lose it again you only have to identify yourself and give the serial number and we will give you the security code again, we also send you a new code card.
How do I enter my security code to my Eurovox radio/cassette/CD Unit?
Refer to the owner's manual of your equipment. Turn ignition key to 'Accessories' & a number '1' or code '1' or similar will appear. Press corresponding preset buttons as you read you security code. If you have a 6 digit security code, the display will count the preset buttons pressed. i.e. display will show '1' the '2' then '3' & so on up to '6' regardless of which number is pressed. If the security code is correct, the radio will turn on. If the security code is incorrect, the display will show '2' or 'code 2' or similar. After 3 incorrect attempts, the radio will go into 'lockout mode'.
Why has my radio got horizontal lines on the display & is not responding to any buttons?
The radio has had 3 incorrect security codes entered & is now in lockout mode. For recent model radio's leave 1 hour (some radio's require ignition key to be on accessories). For older model radio's, remove power to radio by either unplugging radio or disconnecting the negative lead on the battery for 1 hour.
My radio will not accept my security code?
(1) This radio may have been replaced and now requires a different security code
(2)The security code you have been supplied is wrong.
(3)This radio has an internal fault. To check if radio works there is a temporary test code '1111' or '111111' can be used for most of Eurovox Radio. This only lasts for approx 3 minutes.
How do I enter security code to my overhead DVD/Screen combo unit?
Using the <<or>> buttons on the overhead console, scroll up or down to select the first number. Once the correct number is shown, press the ENT button. Repeat this procedure to enter the 4 digit code. As each digit is entered, it will be shown on the display.
Why does "Code Input Error" appears on my overhead DVD/Screen Combo Unit?
If incorrect codes are entered for more than 3 times, your Eurovox overhead DVD/Screen unit will show "Code Input Error" on the display.
Leave car key in the car and turn it to Accessories for approximated 1 hour, the overhead DVD/Screen unit will reset itself and shows"Security Input 1***" on the display.
Good luck... a FixYa rating would be great for my attention to your problem. Cheers mate
regards
Graeme
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
