Question about Zapco C2K-9.0XD Car Audio Amplifier
Zapco 9.0 goes into protect mode and my subs arent even working hard yet
Running 2 jl audio 13w6v2s on a 4 ohm version zapco9.0xd with preclipping set around 1000 watts.
Posted by Greg Rowden on
How to wire a crossfire vr602 2 channel amp at 4ohm and 2ohm
I would be more worried about the amp than the speakers, those subs should handle the watts with no problem. The problem will be in the amps ability to remain working with a bridged 2 ohm load. It may not even stay on without going into protect mode with a 2 ohm load. If it does stay on then it may get really hot and shut off from the heat off of the Mosfett Transistors, or it could burn the Mosfetts from driving them too hard. Basically it's your choice, run your amp hard and gain more volume or run it with slightly less sound and have a cleaner sounding more stable amp that will stay on and have less chance of being damaged. If it's not loud enough the best thing to do is buy a different amp that better suits your needs and fits the application. In your case a 2 ohm stable Mono amp is going to be your best bet or a 4 channel amp bridged into 2 channels and run with 4 ohms on each channel. Or another exact matching amp like your 2 channel amp bridge them both and have each powering 1 of your 4 ohm subs. I used two VR mono amps to power my two 12" 4 ohm subs for a few years
Apr 03, 2013 | Crossfire VR602 Car Audio Amplifier
JL W6 ohm wiring issue
Parallel , all positives together , all negatives together . With 4 ,4ohm voice coils in parallel you get around 1 ohm .
Apr 23, 2012 | Jl Audio Car Audio & Video
How do you bridge the jl audio 450/4
Nice amplifier. However it is best suited for speakers and not for sub woofers. Connect the plus (+) from speaker output 1 and the minus (-) from speaker output 2. Connect the plus (+) from speaker output 3 and the minus (-) from speaker output 4. Now the amplifier is in bridge mode, which will give you 300 WATT RMS at 4 OHM load. If you are bridging the amplifier to run sub woofers then do not forget to set the X- Over to LPF on the channels that you are planning to bridge. Whatever you do, make sure that the load you are asking the amplifier to play is no lower than 4 OHM. Playing this amplifier in bridged mode lower than 4 OHM is a recipe for trouble.
dreamsystems
Feb 12, 2011 | Jl Audio 450/4 Car Audio Amplifier
Amp goes into protection mode when i turn up volume
Sounds like you are running your subs at to low of ohm. Amps are rated differently on the levels of ohms or resistance that they can get to. If you have a dual 4ohm sub and run it in pairrell it will drop to 2ohm and if you run the same sub in series it will be 8ohm. Your amp will go into protection if the ohm is to low.
-david
Nov 07, 2010 | Jl Audio 12W6 Car Subwoofer
I have a JL Audio 12 ich subwoofer rated at 8 ohms. also a mono block insignea amplifier at one ohm stable 1-4 ohms. how to i wire it safley? possible?"
Your amp based on what you say would have no problems whatsoever with an 8 ohm load, not even if it actually has dual 4 ohm coils and you wire them in parallel giving a 2 ohm load (don't know your particular sub).
Every good car amp has protection circuits to prevent itself or the speakers from damage from too low loads so it shouldn't be a problem even if you screw up with your calculations. A good amp should even be capable of dealing with a dead short on a channel, zero ohms, activating protection of course.
Good luck and don't worry!
May 26, 2009 | Jl Audio 12W0 Car Speaker
My amp is protecting unessacarily when ran at 2 ohms
are you factoring the ohm rating from running them parallel?
2 x 2o subs parallel = 0.5 ohm (lowers ohm's)
2x 2oh subs series = 4 ohm
IT is posable that you are calculating the ohm rating fine, BUT some SUBS can reach lower ohm rating while hitting bass- i didnt know this till i had a rather insane sub that would dip to 1ohm while hitting hard bass causing my amp to go into protect mode.
May 21, 2009 | Rockford Fosgate T10001 bd Car Audio...
Is a 15 w3 d-4 better then a jl audio w3-d2
All of the JL W3 subwoofers are essentially the same. The "d2" and "d4" suffix refers to the voice coil configuration. "d2" = dual two ohm coils, "d4" = dual four ohm coils. Depending on the number of subwoofers in your system and the amplifier(s) you are using to power them, one or the other of the configurations may be "better".
Generally, you want to have the load on your amp to have the lowest possible impedance consistent with the amps capability to operate properly with that load. It's normally referred to as "impedance matching". Greater power (watts) is produced, and louder sound, when the amp can deliver power at a lower impedance.
If your amp is only capable of supplying power at 4 ohms, you want to make sure that the configuration of your sub(s) represents a 4-ohm load. If the load is higher, say 8 ohms, then your amp can only deliver about half the power of which it is capable. It would be OK to run them a 8 ohms, but they would not be as loud. On the other hand, if the load was lower, say 2 ohms, your amplifier would soon overheat and go into protect mode.
So the trick is to first decide on how many subs you want. Then choose an amp/sub combination that "matches".
The DVC or dual voice coils just gives you more options in selecting and configuring. Say you want 2 subs and you are going with the 15w3 d-2. Your amp is the JL Audio G-MAX monoblock. The amp puts out 1200Wx1 Chan. at 2 ohms or 600Wx1 Chan. at 4 ohms. You would wire both of your subs voice coils in series making each sub 4 ohms, then wire the 2 subs in parallel to your amp making the final load 2 ohms, the best "match" for your amp.
Mar 29, 2009 | Jl Audio 15W3-D4 Car Subwoofer
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 10w6 x zapco350
These subwoofers are dual 4 ohm voicecoils.
Parallel wiring the 2 voicecoils would net a 2 ohm mono load.
Connect both + on the sub to the + on the amp.
Connect both - on the sub to the - on the amp.
Many professionals simply jumper the 2 + and 2- on the sub.... then run 1 set of wires from one of the terminals to the amplifier.
Thank you for using FixYa - a FixYa rating is appreciated!!
Jan 27, 2009 | Jl Audio 12W6v2 Car Subwoofer
500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
Nov 19, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Car Audio & Video Logo
121 people viewed this question
Top Zapco Car Audio & Video Experts
Marvin
Marvin
Are you a Zapco Car Audio and Video Expert? Answer questions, earn points and help others
