Question about RCA Cable Modem DCM315R (11603540)
Problem decoding from blinking led "internet" light
For unknown reason the "internet" led light on my modem starting blinking. Lost the internet connection. Checked all cables, ethernet connections, everything seems ok. Tried the reset button, and also reset by unplugging the modem, still no luck. When everything is unplugged from the modem with the exception of the power cord, the "internet" light still keeps blinking. Prior to this when I turned the modem off/standby, the cable activity light and PC link lights stayed lit.
Posted by John davis on
5 Related Answers
Anonymous
  • 185 Answers
SOURCE: D-Link Dir-300 Wireless G Router Error 102.
check the cables and try again.
Posted on Aug 16, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: RCA Cable Modem DCM315R Problem:
Who is you service provider and do you have a router connected to it as well?
Posted on Oct 20, 2008
Anonymous
  • 104 Answers
SOURCE: I bought a RCA model
1ST RULE,DON'T BUY FROM A YARD SALE IT MAY BE JUNK.
Posted on Sep 12, 2010
puertobori
  • 7733 Answers
SOURCE: Due to an issue with my router, I disconnected it
Change the cable!
Posted on Oct 12, 2010
Kupoppo
Wesley
  • 58 Answers
SOURCE: When I connect my modem
If the ONLY light not illuminated is your PC link light then that generally indicates a physical disconnect between the modem and the laptop. If you can get the PC link light to light up when connecting to any other device (computer, router, anything), then you are most likely looking at the ethernet jack on the laptop being burnt out. Otherwise, try swapping the ethernet cord. If a different ethernet cord does not resolve the issue and the PC link light does not come on no matter what the modem is plugged into, you are looking at a faulty ethernet jack on the modem.
Posted on Aug 27, 2011
My modem light is orange. every time i reset it it goes from blue to orange
Belkin router is blinking orange is simple but there can be many more reason behind that light code.
1 It just can be ISP issue (maybe internet service provider is down )
2 you might want to restart the modem then router and wait for like 1 min this Belkin router blinking orange to green.
Just follow these steps and let's see if they work for you. restart the modem (DSL modem or ISP device) and restart the router.
Kindly visit for more information regarding your issues
Belkin router blinking orange FIX belkin router amber light Issue
Feb 18, 2014 | Belkin Computers & Internet
Diagnostic light keeps blinking
Check the LED lights that are blinking on the front of the DSL modem. Check the "Internet/Online" LED and make sure it is blinking green or a solid green. If this LED is not blinking, then the modem is not getting a phone signal, or the service is out. Remove the line and check it to make sure that you're getting a signal.
Check to see if filters are connected to the phone lines that are all around the house. These filters separate the phone line from the DSL line so that the lines do not crosswire and disturb the Internet connection or the phone connection. The DSL is usually shipped with a couple of phone filters. These phone filters can be purchased at many electronics stores or provided free from your Internet Service Provider.Check to see if the modem is connected to a wireless router. If the modem is connected to the router, try disconnecting the router and connect the modem straight to a computer. If the modem is also a multi-port wireless router, then connect the computer to a different port on that same router.Reset the router if the previous steps do not resolve the problem. Follow the initial set up instructions given to you when you first installed the router. Perform any firmware updates that might be needed once online, and use the discs that came with the modem.
Feb 07, 2012 | Cisco RVL200 Router
The wireless light is orange and blinking on a Belkin F6D4230-4 router: the wireless is not working
If this did not fix the Belkin router we might need to perform a reset on Belkin wireless router.
For more details kindly visit
Oct 05, 2010 | Belkin Computers & Internet
My internet connection does not work. I can't connect to internet. My modem blinks but it seems it can not find anything to connect to it. It used to work for a few months but suddenly without any reason...
turn the computer off and unplug the modem for few seconds (15) then reconect the modem and let it start all the lights
about (20s) then turn the computer on.
if still cannot connect call your ISP
Aug 20, 2010 | Arris SURFboard SB5120 Modem
All the leds are lit up but the online led keeps blinking.
This light pattern indicates that the modem can not establish a connection to your internet service provider (ISP). This is typically do to a signal related issue. To trouble shoot the problem you will need to connect the modem directly to the main cable line where it first enters into the home. This process is known as bypassing the splitters. You will know when the modem establishes a connection by the top 4 lights becoming solid green. If bypassing your splitters resolved the issue than you will need to replace the malfunctioning splitter. Typically splitter only cost a few bucks and can be purchased from any electronic store. If at any point all 4 top green lights start to blink in sequence than you will need to contact your internet service provider to "unwall the modem". Remember most internet service providers require you to register new modems on there network. So if you have not all ready completed that process you will most likely not have access. If you can not get a connection from the main line than there is a issue with either the modem or the signal coming into the home and you will need to contact your internet service provider.
I hope that information above has helped is some way.
Aug 14, 2010 | Arris SURFboard SB5101U DOCSIS 2.0 Cable...
Blinking the internet light
pls change the ph in cable from the splitter
Apr 10, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Blinking power light no connection
Try this :
If the Power LED is flashing, then power off all of
your network devices, including the modem, Router,
and computers. Then power on each device in the
following order:
1. Cable or DSL modem
2. Router
3. Computer
Apr 03, 2009 | Linksys WRT350N Wireless Router
Siemens ADSL Modem(model- C2110)
siemens c 2110 modem 3 lights flasing continously what to do
Mar 08, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Broadband 2nd Light keeps blinking yellow and then a solid red Light
Ask your Paents to ring the company they connect with it seems to be emulating a disconnection for some reason?
Sep 05, 2007 | 2wire (1000-000057-000) Modem
RCA Cable Modem DCM315R (11603540) Logo
161 people viewed this question
Top RCA Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
