Broiler not working on accubake oven
Whenever you read out any part with a meter you have to pull at least one of the wires off of the part you're checking,unplug the machine,slide it out,remove the back panel so you can see the broil wires and the ends of the element,pull off the wires and check it with a meter for continuity,set the meter on 20k ohms,touch the leads together and it should read anything but 1,then touch the leads to the ends of the element, if it stays on 1 the element is bad if you get any other reading other than 1 the element is good,also while you're back there but be careful,plug the machine back in with the element wired, set the meter to volts and check to see if you get 120 volts to the broil element if the element checks good,if you check the bake element you should have 240 volts,if the element is good you could have a broken wire or a bad computer board or also called the clock assy.i've seen the elements burn and break and short out the clock assy. and it doesn't mean the clock doesn't work,it's the way they're built the computer board is built in with the clock that's all so if the computer board gets damaged the clock still can work so if you check it with a meter
