Cisco Unified Communications 500 Series for Small Business - VoIP gateway - 0 / 1 - 8 users - EN, Fa... Router Logo
Dan Laube Posted on Nov 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cisco Unified Communications 500 Series reset password with out losing my configuration
Anonymous
Level 2:
New Friend:
  • Expert 55 Answers
  • Posted on Nov 17, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
55
Questions
0
Helped
8897
Points
113
if you are talking about your enable password you will have 2 choices which are a factory reset or evoke ROMMON. The simplest way is to backup your running config via TFTP or do a #show run and copy and paste the whole config to a txt file and then reset to factory default and then just load(or paste) that config and then do a #copy run start.
3helpful
2answers
How to retrieve Cisco router password without losing configuration?
Need help to recover the forgotten password of your Cisco router? The following guide will help you restore the password without losing your router configuration. To retrieve the password, you will require rebooting your router many times. It means stoppage, but it is the best step to reset the password. At first, you need to connect the first end of the standard light blue cable to the power port and the other end to the 'Console' port on the back of your router. After connecting the devices, you need to make a serial connection to the router. For that, you need the following settings:
Baud: 9600
Parity: No
Data bits: 8
Stop bits: 1
Flow Control: None
To recover the Cisco router password, check the following steps:-
1.Restart your Cisco router and press the 'Break' key to conflict the boot order. Input config 0x2142. It conveys the router to avoid NVRAM in the boot process. It won't load your current configuration.
2.Enter reset to restart your router. When asked to run the setup process, choose 'No.' Enter 'Copy Start, Run.' It loads the beginning setup into memory.
3.Now, if you enter the 'Show Run Config,' it will show you the router settings. Also, you should consider that the router name is in the prompt rather than the default 'Router.'
4.Type the 'enable secret new password' to change the enabled secret, and then enter the 'config-register 0x2102' to modify the registry settings back to 0x2102.
5.Once your router restarts, it will load the old settings along with the new password. Now, you need to save it so that it will continue during restarts.
6.Enter copy run start. Type Reload at the prompt to reboot the Cisco router.
Now, note down the password to keep them safe. However, if the steps as given above fail to recover the Cisco router password without losing the configuration or you need the help of experts, you can call on the genuine Cisco customer care number listed on the Contactforhelp to get the direct support of experts for recovering the password quickly.
tip
Guide to Reset Password on a Cisco Router
How do I reset the password on my Cisco router?<br />I bought a Cisco 1700 router from an auction, but there is a password. How can I reset the router to original factory specifications? <br /><br />Sky sagem wireless router reset password? I just got this sky wireless router second hand and it has a password set on it. i tried to press the reset button at the back but it does not do any thing, it still comes as a password is set.<br /><br />How to reset password on dlink wireless router? I have a dlink wireless router model number DIR 825 . It works good but I am trying to access internet on my ipod and the password i have set is incorrect , this also happened when i tried to access internet on my laptop. When i first set up my ps3 i dont recall having to put a password in but this was when i first got the router. How do i reset the router password or find out what the password is AND if i reset the password or reset my router will my ps3 have to be reconnected or will it stay?<br /><br />How to reset password on a router? I recently acquired a linksys router (used) and need to know how to reset the password so that I can use it. Also, is there any way to modify a router to be useful as a cell/wifi blocker, or as a signal booster?<br />... <br /> ----From Yahoo Answers<br /><br /><br />To reset password on a Cisco/D-link/Linksys/Netgear router is a very common problem among people who want a secure network environment for surfing on the internet. If you are confused with the complicated procedure to reset or change the password on a router, or if you are trying to configure a Cisco router, but a password is blocking you from enable mode, don't worry, just do the steps as follows, password reset on a router is no longer upset to everyone.<br /><br />First, be informed that what you need:<br />.<a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router</a><br />.Computer<br />.Internet Connection<br />.Blue Serial Cable<br /><br />Guide for You to Reset Password on a Cisco Router:<br />1. Download a program called Putty from the first resource site below. PuTTy is a terminal emulator application which can act as a client for the SSH, Telnet, rlogin, and raw TCP computing protocols (PuTTy on Wikipedia).http://en.wikipedia.org/wiki/PuTTY<br /><br />2. Connect one end of the blue serial cable to the Cisco Router and the other to your computer. Open up the Putty program on your computer and select the radio button next to "serial" on the right-hand side of the start window. Click on the "Open" button in the bottom right-hand corner of the Putty start window to open the terminal.<br /><br />3. Power the Cisco Router on. As soon as the router begins loading in the green and black Putty terminal window, press the "Ctrl" and "Break" keys simultaneously until its going into rommon mode.<br /><br /><br />4. Once in rommon mode, you have to change the configuration register number to make the router boot from a blank configuration file. For the 2800 series Cisco Routers, the command "confreq 0x2142", changing the register number to 2142, worked. Search on cisco.com for information on your particular <a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router Series</a>.<br /><br />5. Type the restart command in rommon mode, which is "reset". This will boot the router up again. When it is finished, you should be able to type "en" to get into enable mode without a password.<br /><br />6. Once you change the running-config in RAM and save it to the startup-config in NVRAM, remember to change the configuration register number back to its default (usually 0x2102). This is important if you change anything on the running-config. <br /><br />Easy five steps help you finish resetting password on a Cisco router. Easy instruction, easy to follow. <br /><br />
on Jul 19, 2011 • Computers & Internet
tip
Cisco 1800 Series, Business Router for Small to Medium Sized Business/Enterprise
Cisco 1800 Series Integrated Services Routers, the next evolution of the award-winning Cisco 1700 Series modular access routers, own more advantages than the formers. Cisco 1800 series, ideal for small to medium-sized businesses and small enterprise branch offices, enable businesses to reduce costs by deploying a single, resilient system for fast, secure, delivery of multiple mission-critical business services, including data, security, unified communications, wireless.<br /><br /><a href="http://www.router-switch.com/Price-cisco-routers-cisco-router-1800-series_c17">Cisco 1800 series router</a> has several models including 1801, 1802, 1803, 1811, 1812, 1841(most popular), 1861, all of them have some common features: a. Designed for small businesses or branch offices and to offer secure wireless networking; b. Multiple performance options based on local, remote, or broadband connections; c. Integrated security including encryption and protection against hackers; d. Virtual private networks for linking to partners, suppliers, and remote offices; e. Multiple options for adding reliability and option for reduced costs by using power from network cabling; f. Software upgrades to add new features and functions, and integrated switching capabilities.<br /><br /><a href="http://www.router-switch.com/Price-cisco-routers-cisco-router-1800-series_c17">Cisco 1800 series</a> router has several models including 1801, 1802, 1803, 1811, 1812, <a href="http://www.router-switch.com/cisco1841-p-97.html">1841</a>(most popular), 1861. You can check details of every type as follows:<br />The fixed platform models (1801, 1802, 1803, 1811, 1812) include multiple WAN interface options, plus:<br />Up to broadband speeds<br />Eight 10/100 Mbps built-in switch ports with optional Power over Ethernet (PoE), for providing DC power to network devices such as IP phones<br />Up to 50 VPN tunnels<br />Support for wireless local-area network (LAN) standards 802.11a/b/g<br /><br />The 1841 is a modular platform with a wide range of interface options, plus:<br />Up to T1/E1speeds<br />Up to four 10/100 Mbps built-in switch ports<br />Up to 800 VPN tunnels<br />Support for wireless local-area network (LAN) standards 802.11a/b/g<br /><br />The 1861 is a modular platform built on a fixed base with a wide range of WAN interface options, plus: <br />Integrated Cisco Unified Communications Manager Express or Cisco Unified Survivable Remote Site Telephony for call processing<br />Cisco Unity Express, for voice messaging and automated attendant<br />Integrated LAN switching with Power over Ethernet (PoE) expandable through Cisco Catalyst Switches<br />Onboard voice ports for PSTN, PBX, and key system connections<br /><br />With Cisco 1800 Series integrated services routers; you can lay the foundation for future growth and prepare for voice, video, wireless, and security solutions tomorrow. <br /><br />If you want to know more about e about the certain type of Cisco 1800 series, you can visit the list of Cisco 1800 router series, prices also offered.<br /><br />
on Jun 30, 2011 • Computers & Internet
How to access Cisco Unified Communications Manager Administration ?
from what I have researched on the web you need to download the Cisco unified Communications Manager software on to the P.C you wish to use to access the server via the web browser. it states you open the software via a web browser. The reason being the Voip server has no software on it.
http://www.cisco.com/web/developer/cucm/content/download.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_5_1/CUCM_BK_A09578D7_00_admin-guide-cucm-imp_1151/CUCM_BK_A09578D7_00_admin-guide-for-cucm-1105_chapter_01.html
3answers
What collaboration capabilities are available on the new Cisco 2900 and 3900 Series routers?
According to my experience and knoledge: the Cisco 2900 and 3900 series platforms have collaboration feature parity with the Cisco 2800 and 3800 Series platforms, so all of the following collaboration capabilities and solutions are present:
• Cisco Unified Survivable Remote Site Telephony (SRST)
• Cisco Unified Border Element
• Time-division multiplexing public-switched-telephone-network (TDM PSTN) and private-branch-exchange (PBX) gateways
• VoiceXML contact-center gateways
• Cisco Unified Communications Manager (UCM) media resources (allowing conferencing, transcoding, and Media Termination Point [MTP])
• Resource Reservation Protocol (RSVP) Agent
• Cisco Unified Communications Manager Express (CME)
• Cisco Unified SIP Proxy
• Gatekeeper
Cisco 3900 Series Routers
Hi when i reset cisco srp521 router, what will be the username & password for admin user. thanks aks
The default username is admin.
The default password is admin.
that's the default passwords. it does depend on the type of reset whether you will still have the old passwords or not. be that as it may i'm also including the user manual for you
http://www.cisco.com/en/US/docs/routers/srp520_series/srp521w/administration/srp500_admin.pdf
i do hope this solution helps you
thanks
robert
Can Cisco do the equivalant of Nortel DISA
DISA can only be accomplished using Cisco callmanager and it's accompanying product unified contact center expresss.  You would have to build a custom script in contact center express to accomplish this.  If you are interested, please contact me @ [email protected] for further info.
3answers
Having issues with logging into the cisco softphone from home via vpn
Make sure that the subnet for the call manager is available over your VPN if you have locked the tunnel down. Also make sure that the IPC is allowed to bind to the VPN virtual network card.
Hope that helped!
2answers
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
