Question about The Learning Company Calendar Creator Standard 6.0 Full Version for PC
How can i install a program onto windows xp if the software says for windows 98?
Posted by Ron Maslanik on
Vikram Singh Rana
    New Friend:
You could visit the vendor's website and download a version for you operating system. If you don't know the vendor's website then simply search in Google for the required software. For example if I need to download express scribe for mac I will search in Google with the following keywords "download express scribe for MAC". Once you have downloaded the software you can install it by double clicking it.* Express Scribe is a software used for transcription.
Posted on Dec 04, 2011
I need vga compatible driver of hp pavilion ze2000 laptop for window xp plz help me
http://majorgeeks.com/SiS_UniVGA3_Graphics_Driver_d4401.html SiS VGA software package consists of VGA drivers, utilities and Installation/Uninstallation programs for Windows Server 2003, Windows XP , Windows 98 SE, Windows 98, Windows ME, Windows 2000, Windows XP 64-Bit Edition, Windows Server 2003 64-Bit Version. The installation/uninstallation programs are capable of installing/uninstalling VGA drivers and utilities respectively. ur utilities consist of utility manager, driver mode setting utility, gamma correction utility, video setting utility, TV output setting utility, center screen for TV, product and file information utility, utility tray, and hotkey define utility. hope this helps
May 10, 2012 | HP Computers & Internet
I have tried to install the rosetta stone (original, not a copy) application disc onto 2 different computers I own. One computer has windows vista and the other windows xp. I get this error message on...
Copy the entire cd contents to a new folder on your hard disk, locate the installer/launcher icon inside the folder "Setup.exe", select it and right click on it, go to properties. under compatibility select windows 98 or windows me. press apply or ok, then double click the icon. The program *should* launch properly and install your software. Its a problem with memory resource allocation being different on newer operating systems. (thus why the added the compatibility function for older programs)
cheers.
Aug 29, 2010 | Computers & Internet
HOW DO YOU INSTALL A SECOND OS ON A SLAVE DRIVE. I AM RUNNING WINDOWS XP HOME EDITION. I WANT TO INSTALL WINDOWS 98 SECOND EDITION ON A SLAVE DRIVE DISC. SOME PROGRAMS I HAVE WILL NOT WORK ON XP.
You cannot install 98 directly on your system slave drive, but there is a way to install it.
1) disconnect your primary drive
2) make your slave drive as primary.
3) install 98
4) Connect your actual primary drive again and start your system
XP records your mac id of your motherboard and 98 does not records, the other way is, you can install both the OPS on your one primary drive by creating different partitions, you will need to full format your drive first.
1) Full format your primary drive.
2) Create partitions.
3) Install 98.
4) Install XP in different drive of your same hard disk
You will be able to see both your OPS when you start your system.
Sep 18, 2009 | Computers & Internet
I have a problem to install window 98 .
Another solution is to download and install Microsoft Virtual PC in XP, create a Virtual PC drive, and install Windows 98 onto the Virtual PC drive. This works fine if you want to run Win 9X programs which don't require access to USB ports on your computer. If you need Windows 98 to have full access to all of the computer hardware, then use palaboy's solution.
Apr 21, 2009 | APC USB Port Version For Windows 98...
I can't install Data Becker CD LabelMaker On Windows XP
You asked a long time ago. If you still use XP get Plus! for Windows XP, which contains a label creator programme based on the Data Becker software. Works perfectly.
Jan 19, 2009 | Databecker Instant LabelMaker (2087368)...
I can't install it.
Ensure that you are running XP Service Pack 2 version, this software won't work on Windows previous version.
If you are using 98, you need to upgrade system.
If you are using XP you may need to upgrade service pack 2, see Download details: Windows XP Service Pack 2 .
Jan 04, 2009 | Sony Vegas Movie Studio Platinum 8
I am trying to load the software from my older scanner onto my gateway computer, that now has Windows XP and the software only uses Windows 98
HI YOU NEED TO RIGHT CLICK ON THE SETUP FILE THEN PROP AND THEN COMPATABILITY THEN CLICK BOX AND CHANGE IT TO 98  THEN APPLY THEN INSTALL IT
Dec 04, 2008 | Computers & Internet
Vista Driver for JVC Camcorder GR-DV900
      Unfortunatley your answer is within your question, in which you say it only came with Driver Support for Win 98, 2000 & XP, basically meaning that your Camcorder is not compatible with Windows Vista.
      The only 3 Possible choices you have are to
1. Use a friend's PC who has XP installed, and Transfer the Files through using their System.
2. Remove Windows Vista, and Install Windows XP
or
3. Wait until your Camcorder is supported by Windows Vista.
I seriously should not wait for Option 3 though, as I've had a Philips Webcam for over 2-3 yrs now, and is still not supported by Windows Vista.
Nov 29, 2008 | Computers & Internet
YM makeover magic
windows nt is a operating system some software works only with windows 98or only with windows 2000or only with windows xp/nt windows nt is the same as xp i think the software ym makeover magic works windows nt platform you should have the operating system in which the ym makeover magic works to know which operating syatem works just see some readme files in setup files folders of the ym make over magic there will be file stating readme in that they will give operating system comapatiblity windows 98/2000/server 2003/xp/media center /vista they will specify like this see the compatiblity and then install the operating systm and then install the software
May 09, 2008 | Face Cake YM Makeover Magic (95919)
The Learning Company Calendar Creator Standard 6.0 Full Version for PC Logo
Top The Learning Company Computers & Internet Experts
k24674
Mike
ghiemman
Level 1 Expert
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
