Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher Logo
Question about Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher
Fisher paykel dishdrawer keeps beeping with f1 error
Posted by linda mills on
F.P.D.Draw Alt Solutions
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
Http://www.scribd.com/doc/6462163/DD601V2-Manual#fullscreen
Posted on Sep 13, 2013
5 Related Answers
Anonymous
SOURCE: F1 code on Fisher and Paykel dishdrawer
Linkages to guide hosing deteriorate + crack over time + will cause a problem over time- hoses get caught between drawer and lid on top of the drawer. Solution - repair perished sections of linkages to guide hoses.
Posted on Aug 06, 2007
Anonymous
SOURCE: dishwasher f1 problem on fisher paykel
先谢谢啦
Posted on Feb 21, 2008
Anonymous
  • 3 Answers
SOURCE: Fisher-Paykel DD603 DishDrawer shows F1
See also http://www.fixya.com/support/t346941-f1_error_1_draw_dishwasher
Posted on Nov 03, 2008
biigg53566
Alan Matzke
  • 113 Answers
SOURCE: My dishwasher keeps flashing F1 error message
The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
Posted on Nov 18, 2008
Anonymous
  • 145 Answers
SOURCE: current service manual for the Fisher & Paykel DD603SS dishdrawer
I realize this is an older post but for information's sake in case someone happens across this subject, you can get the manual for a DD603 series dishdrawer here:
http://www.fisherpaykelparts.net/index.php?categoryid=115&productid=18
Posted on Dec 15, 2008
1helpful
2answers
I have DW60CDX2 , Turning on but buttons are not responding when I pressed buttons?
from what I'm seeing for the dishwasher, an E1 error means that the door is not properly closed. So, please look at the door of the machine to make sure that nothing is broken or that the dishwasher isn't too full. Thank you.
White whale Dishdrawer Error Code E5
Fisher and Paykel Dishwasher Dishdrawer Error Code E5 = The first 3 program indicator lights are flashing. Error Code Cause: Water supply hose is crimped or bent. Drain hose is too low. Water tap not turned on. Not enough water supply pressure.
https://removeandreplace.com/2016/06/07/fisher-and-paykel-dishwasher-dishdrawer-error-codes-and-troubleshooting-how-to-fix/
Dishwasher keep beeping F1 and F5
F5 is the fast and rinse LED
It simply means the lid motror current is to high during the start - The lid is jammed up or down. Or the electronic controller has failed!!
Errors and restarts
will need a description of the problem. Some of the common fault codes are F1, F2 and F3.
All these fault codes stop the dishwasher and will not go away until the cause is removed. Please indicate the problem you are experiencing.
1helpful
Fisher and Paykel dishdrawer ds601
when it is beeping is there any code on the screen such as F1? (if not a screen model there will be a sequence of lights where u select the cycle) also can you hear the drain pump running nonstop till you turn it off at the wall? when you get back to me ill run you through getting into the diagnostics and test cycle program to check all the components, but from the sounds of it you may have a leak causing the flood switch to trigger
I have fisher&paykel dishdrawer and f1 problem. what doew it means;
Hi
Please check this link to troubleshoot your problem in dishwasher if it shows F1 error:-
http://www.ehow.com/how_7307602_troubleshooting-error-fisher-paykel-dishwasher.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 • Dishwashers
Hey got a set of dishdraws and when ever we turn on it starts beeping and flashing F1
F1 Error is the Flood Switch. This Usualy mens there is a leak that has Triped the flote switch.
There are many things that could be leaking to cause this.
You should have a pro look at this machine.
3helpful
Our F & P dishdrawer keeps coming up with f1 and a picture of a spanner have tried turning the machine of at the switch for 24hr but is still doing it
Water has collected at the base of the dishwasher under the drawer.
This triggers a flood switch and causes the F1 error.
Turn the mains power off and extend the drawer out as much as possible. Take towels to dry the base from inside. Also use hair dryer ot dry out the flood switch mounted at the base.
Turn the power on and see if there is any difference. The cause of water collection could be many. Foam in detergent or kink in drain hose or drawer door gasket leaking etc.
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
