Question about Canon DR-9080C Path-Through Scanner
Paper will not feed. the lift tray does work. 1.5 to 2 inches of the top of the paper feeds before it stops. when i used count only still get the same problem with
Posted by Alyce Lee on
  • Alyce Lee Nov 17, 2011
    error message "A01"
Mohan Sriraman
  • 490 Answers
A01 is pickup error. Clean the paper sensor in the paper lifting tray and try. Clean the rubber rollers also.
S. Mohan, Chennai, India
Posted on Nov 19, 2011
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
HP LaserJet 1012: The paper has stopped feeding. I hear the feeding mechanism rolling, but the paper does not feed.
Check the adjustment of the guides in the paper tray. There should be about an 1/8 inch of play from front to back so that the sheets of paper so they can be lifted from the tray. If the stack of paper is snug, move the rear guide back a little bit.
Feb 27, 2011 | HP LaserJet 1012 Printer
Feeds ok from tray 1 but not tray 2 which is 11x17. There are slight buffed marks at on the papaer in 4 spots but paper wont advance. marks are about 1/4 inch long
those marks are the rollers trying to move the paper. check to see if your tray 2 is lifting.if it is then replace the feed rollers.
Sep 28, 2009 | HP LaserJet 4mv Printer
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Sep 08, 2008 | Office Equipment & Supplies
Kodak PD6000 Printer Dock will not lift and feed paper from paper tray
Greetings,
Here's the link for your products Troubleshooting Guide
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
Jul 30, 2008 | Office Equipment & Supplies
Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
Feb 07, 2008 | Sharp AL 800 Copier
Paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
Canon DR-9080C Path-Through Scanner Logo
231 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
