The camera is not working.
SOURCE: putting music on the lg prada
you need to plug the usb you had with the mobile where you insert the charger with pc and transfer data or music from pc to the mobile.
try to plug the wire usb first . on your pc it will open a page written as removable disk .
the open your music documents make copy the one you want and on removable disk make paste you can work with this
SOURCE: LG PRADA / KE850
So there is no way to fix the phone if there is problem(ex. not working screen)?
SOURCE: Micro sd card in ke850
When the Prada 1 (KE850) was launched, it officially only supported up to 8 GB SD(HC) cards, but there are SD card manufacturers (i.e. Kingston) which claim that their 16 GB cards work in a KE850.
You could contact LG Customercare to confirm this or go with the 8 GB card to be sure ...
SOURCE: CHANGING HOUSING FOR LG PRADA KE850
Hi Purnimakant,
It's very easy to do and I have done it myself.
If you check out:
http://www.formymobile.co.uk/Dismantle/ke850disassembly.htm
There are step by step pictures there.
You can find a new case on eBay. I changed from black to silver :)
Hope this helps.
SOURCE: LG KE850 Prada network Block simcard
LG KE850 states sim card is not supported...what do i do?
the camara for my LG prada phone KE850 is not working.what i need to do?
