Previously linux was installed on the machine. Reinstalled xp tablet edition, but cannot seem to get the touchpad/pen and touchscreen to work properly. I have the machine up to date and tried installing drivers from fujitsu, but to no avail. Is anyone having a similar problem? Does anyone have any advice?
SOURCE: Fujitsu laptop, touchpad stops working when connected to power adapter
dear
the consumption power ampere is symptom to your voltage of touchpad
trying installing driver touch pad again
and try to use FN + F9
oke
cropp
SOURCE: how do i restore to factory without any restore
It is not possible to restore to factory setting without the accompanying restore disks. You can attempt to contact Fujitsu Siemens and obtain a set of repair disks from them.
Your only other option is to obtain a retail copy of Windows and perform a new installation, then download the required drivers from the Fujitsu Siemens web site.
SOURCE: Win XP on Fujitsu stylistic lt c-500
Ok... after much slaving, trial and error, and just plain getting frustrated I finally figured out how to install XP on a Fujitsu Stylistic LT c-500 with EVERYTHING working!! The installation is difficult and time consuming but well worth it. Getting XP on the blasted thing is part of the difficult uphill battle... but Mr. Mark Rehorst does a wonderful job of explaining it here. Follow the directions carefully keeping in mind that you MUST have the cd-key for the EXACT CD you use... and that to install XP and get everything to work you really need at least a 20gb hdd and 256mb ram. Without those your system will be slow. Next once XP is up and 'running' you'll notice that your touchscreen is not working. Download the CIC XPen off of the Fujitsu support site... now here comes the interesting part. Unpack the driver to C:\Drivers\Pen once you've unpacked it find the file called fujpen.inf open it in notepad to edit it. You will see:
[ControlFlags]
ExcludeFromSelect=*FUJ02B6
Make sure the last digit is 6 in that string... this is saying to exclude that model in the driver. If it's anything other than a 6 change it to a 6. Now then... further down you'll see:
[FPC.Mfg]
%FPC.DeviceDesc0% = pendrv, *FUJ02B6
Now... remember what I said about the 6 above? Yeah... the driver is fighting with itself, help it out and change the last number to a 7. Save the .inf file. Go to your device manager right click on the unknown device and update it with the modified file... and presto changeo your touchscreen works!! Now for the other unknown device in there, it is called the Fujitsu FUJ02B1 Device Driver. Unfortunately Fujitsu dosen't include a driver for this... but if you google search it you should come across driverguide.com and they'll have it. You will have to sit through a few ads to get it... but wow... the world that is unlocked by xp on this tiny little pad is amazing! Good luck!
SOURCE: tablet buttons and key board
You should downgrade (at your own risk) to Windows Tablect PC Edition, not just any Windows XP.
Hope ti helps
SOURCE: I have a Fujitsu Lifebook
Check out this link @ http://www.pc-ap.fujitsu.com/support/drv_lifebook.html
Go to "LIFEBOOK T Series" Select your Model T4210 ->GO
Then select your OS to download the drivers & software for needed for Laptop.
Hope it helps.
