oh..............!! you can try 1111 on your pc first......then the cnnect your mobile to the pc and when they ask for the pass code in your mobile type the same (that is 1111)........this is my suggestion...you keep trying it.....thats what i did......if you are lucky you problem is solved.
Phone: Turn on Bluetooth and Bluetooth visibility. Keep it close to the headset (20 cm).2. Headset: Switch it off. Press and hold down the on/off key until the pairing icon appears on the display.3. Phone: If your phone supports auto pairing, press YES when Add device? appears to complete the procedure. If not, continue with the next step.4. Phone: Follow the applicable User guide to pair with a Bluetooth headset. You may need to enter a headset passcode (0000).
Usually the code is something simple like 0000, 5555, or 1234. Another way is to check your phone's manual, or google your phone name + bluetooth code.
How to connect or pair a Blueant Bluetooth handfree. 1. Switch off the Blueant: i.e. push the microphone inside the Blueant. 2a. Press and hold the GREEN telephone symbol (or Accept) pushbutton On the Blueant flat face for 8 seconds. (this makes unit go into “pairing” mode) 2b. at the same time switch Power On to the Blueant by pushing out the microphone on the side of the Blueant. 3.The Bluetooth Indicator will turn a blinking red/blue, when you see this, release the Accept Button . The Blueant is now in “pairing” mode. 4. Get you mobile in Bluetooth search mode to pair with a new device. 5. The Blueant will request your mobile device for a password. 6. Enter the password= 0000 , the devices now will be paired.
7. Set the Blueant as a trusted/authorized device, if this is option in your phone.
Also note that some of the IHF1000 carkits may also use 1234 for the passcode. When you go into the Setup Menu and ask it to Pair a Phone, the prompt will tell you the correct passcode (0000 or 1234) to enter by saying, "Enter xxxx, when requested".
