Question about HP LaserJet 4730 MFP Printer
HP Color Laserjet CM4730 Scanner Not Initializing
We Replaced the DC Controler ,Formatter Scanner Control Board & Flat Cable it comes on but Ready ,Attention & Data Lights Flicker
Posted by Arnold on
Craig
  • 27 Answers
I had an issue similar to this and it was fixed by replacing the memory dimm on the bottom of the formatter.
Posted on Dec 08, 2015
5 Related Answers
leo_mart
  • 4 Answers
SOURCE: HP 4350 printer
you might need to upgrade the firmware
Posted on Feb 11, 2008
Anonymous
  • 32 Answers
SOURCE: HP color LaserJet 2600n stucked on Initialzing
Well we can check and see if the printer is able to run an engine test. This is how you can run this test;
  1. Turn the printer around so the back of the machine is facing you.
  2. Remove the Engine etest button acess door. This is located in the bottom center of the back.
  3. Push the botton once while the printer is on. The printer should print a page with colored horizontal lines.
If the printer is able to print this page there is a very good indication the problem revolves around the PCA formatter board.
The Firmware might be outdated and causing this problem. Worst case scenario the board might be faulty, in that case your better off buying a new machine, since the cost to replace the board will be higher than that to replace this machine.
Posted on Nov 19, 2008
sys_admin
Milind Shetti
  • 829 Answers
SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Posted on Mar 22, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: Hp 4300 laserjet. All printouts have a blank space
Remove the toner and wipe the small window that's above where the drum unit sits inside. That window gets covered with toner and makes light prints and blank areas.
Posted on Nov 18, 2009
Anonymous
SOURCE: HP laserjet 5550 not printing cycan. Replaced
You will not find the answer to this problem on any forum as I have searched each one! However I have had the same problem and found out that if you have reseantly replaced or reseated the Paper Pic-up assy you may have not pushed down the plastic top cover which sits directly underneath the Cyan Cartridge, this will cause your 5550/5500 to think there is no problem and carry on printing without any error messages.
I'm just a man doing a boys job, lol
Posted on Feb 23, 2010
Testimonial: "Wow! Thank you sir. That was the problem. I had not touched the paper input assembly. So obviously, a user did this. Thanks again!"
Initializing scanner hp cm6040
Most common cause of the error on this printer is the memory on the CPB (copy processing board) is bad. This board is picky about memory and typically only works with the actual HP memory designed for it. The easiest fix is to use the memory that is currently installed on the formatter, which is identical, and purchase 3rd party memory for the formatter, which will support any compatible memory.
May 07, 2016 | HP Color LaserJet CM6040f MFP Q3939A...
Error code 55.4k
This error 55.4k appeared in printer hp color laserjet 5550. The following trouble shooting did. Orignally my printer fault is display blank.Then i replace dc board with formatter board. blank is gone dueto new ram.Machine display showed the memory process. but immediatly the error 55.4k appeared on display.The reason for this error is, communication failure between formatter and dc board.The dc board which i was replaced by old type one.Then i found exact same dc board, replaced. Error was gone.Machine came to normal status , working fine.
Oct 01, 2013 | HP LaserJet 5550dtn Printer
HP CM1312 DISPLAY DEAD, READY LIGHT SOLID, EXCLAMATION POINT SOLID
I hope its formatter(mother board) faulty,remove USB cable, un install the drivers from the system, found new hard after connecting the printer? if its not recognizing replace formatter assm..or else display panel..Hints while repairing: Flat cable is too short between scanner assm & DC controller, before powering on verify this cable properly fit or not.. While opening the printer side covers by mistake flat cables of ADF & display plug off due to over length, if we are not concentrate on this it will damages the formatter,if we gives power(might be this issue raised in your printer)..Never disturb/remove the laser scanner assm.. it will kill your patience.Never try to remove laser scanner assm with out cartridge bank( for repair normally we will remove this bank), it will fall down on ETB.. verify all connector properly fixed or not before powering on..
Dec 30, 2011 | HP LaserJet CM1312 All-In-One Printer
Error 55.1
Hello ,
you have open the printer itself, the connection between formatter & dc controller is not proper pls reseat them if further problem persists then replace the dc controler pca,this problem may be genrated by high voltage.
Regards
jm
Oct 28, 2011 | HP Color LaserJet 2600n Printer
I owned HP CM1312 mfp. I have problem with color prints. No any color is printed except black. I changed dc controller but the problem remains... Could you please help?
I hope you did calibration..The Flat cable from laser scanner assm to DC controller is very short & narrow, while connecting it to DC board little bit it will come out at scanner assm PCB, remove upper portion up to laser scanner assm refix flat cable both ends of DC & laser pcb. fix all back & try.. I hope it will resolve the issue.. Best of luck...
Sep 27, 2011 | HP Laserjet CM 1312NFI Color Printer
HP Color Laserjet M5035 get`s error 30.01.34
First, this model is not color laserjet, only black.
HP LaserJet M5035 MFP
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. If the message persists, replace the scanner control board or replace the formatter.
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
Hp lazer jet 2600N won't print red color what will fix it. Has a new cartridge
You may need to replace FORMATTER BOARD & DC CONTROLER BOARD ASSY which are located behind the printer. Both BOARDs are side by side together. Just open the back cover, you will see it.
Jun 10, 2010 | HP Color LaserJet 2600n Printer
HP 4650 stops at "initializing"
REMOVE THE BATEERY IN THE CARD AND DO COLD RESET
Apr 20, 2009 | HP LaserJet 4650 Color Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 4730 MFP Printer Logo
1,785 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
