I purchased a new grip/trigger handle, but now my original supply hose fitting doesn't fit the new handle. It appears that the thread size and I.D. are different and things don't line-up/fit. Does anyone know if I can adapt the original hose to the new handle? Is there a fitting I can purchase that can replace the one on the hose now?
SOURCE: Water leaks where the hose connects to the trigger handle.
Be sure to get a good washer on with the connection. They're easy to buy at any hardware store. You can also put white plumbing tape around the threads before screwing them in to make it really fit.
SOURCE: Bissell Proheat only sprays for a few seconds.
When was the last time you changed the flat belt? Even if it isn't broken it could be so stretched out that when the brush hits the floor it slows or stops the pump from spraying. If its a new belt then and your sure there arent any clog's that usually means the pump is bad. Also if youve ever used anything other than bissell shampoo in the machine it could have ruined the pump as well.
SOURCE: My mother purchased a replacement hose assembly
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hggj
SOURCE: How do I get an
I went to OSH hardware. I unscrewed and took the portion of the faucet- that the hose from the steam cleaner was to fit into and I took the hose right into the store. I just bought my unit at the thrift store. Works great. I love it!
