If the pickup in the guitar suddenly stops working - then most likely there is a solder connection that has come loose. If you can get a small dental mirror, you may be able to look through the F-Hole on the guitar and spot the loose wire. The tricky part with a Sheraton is the way the hollowbody is constructed doesn't allow you to work on the electronics as easily as say a Fender Strat.
The only way to fix this would be to carefully remove the electronics and re-solder the bad connection. You should only do this if you are very comfortable with soldering.
Since the bridge pickup fails, yet the neck pickup works, you can eliminate about 1/2 of the problem. You can start by examining the wires that come off of the bridge pickup and follow them to the next connection point. You can also test wire continuity if you have a multi-meter to hook up to the wire - to check that the actual wire is not broken in the middle. (Broken wires on the inside of the guitar would be rare - more likely it will be an obvious solder joint that has come loose.)
If you have a local mom and pop music shop nearby - you may be able to take your guitar in for a free diagnostic - but that depends on the shop.
Good luck! Hope my information has helped you figure out a path to get it working again!
