Question about Electrical Supplies
What sparkplug is for the Sportsman GEN7000LP Propane Generator?
The sparkplug in the generator simply says LPG GREEN POWER..it has no numbers. Buffalo tools wants $6.00 for a plug with $7.00 shipping. Does anyone know what sparkplug works for the SPORTSMAN GEN7000LP Propane Generator?
Posted by Dave I. on
  • 1 more comment
  • Dave I. Mar 04, 2012
    I finally found out the equivalent spark plugs to use in the Sportsman Gen7000LP..
    Tried to put this on Home Depot site but they wouldn't let me do duplicate review..
    Found the answer here...http://newriverfirewood.com/Sportsman-70...
    The equivalent sparkplugs are
    F6RTC included (Comparable: Bosch WR6DC, Champion RN11YC or NGK BPR6ES).
  • James C Nov 14, 2020
    The absolute best replacement spark plug I have used so far for this generator is the AC Delco R43XLS. It has never missed a beat and resists fouling better than the other brands. Like anything else results may vary based on the condition of the engine itself. I do change the oil far more frequently than the recommendation but that is inexpensive insurance in my mind. Good luck.
  •  Generator Guru Parts
    We sell them.https://www.generatorguru.com/
  • 18,564 Answers
Take the plug out and go to Home Depot. Buffalo Tools makes that unit and Home Depot is a seller
Posted on Nov 14, 2020
5 Related Answers
Anonymous
  • 61 Answers
SOURCE: LPG / NG portable generator runs on propane but
While propane and natural are similar, some devices require changes to properly operate on the selected fuel.
Information about this should be in the owners manual for the unit.
An off the cuff guess is that the gas pressure from the NG source isn't high enough, or that there is a gas regulatior on the generator that would need to be adjusted for NG.
Posted on Oct 27, 2009
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: where can I get parts for a 1000 watt buffalo tool generator
Try Ebay for I did on mine
Posted on Jan 17, 2010
Sheldon Dedek
  • 912 Answers
SOURCE: Looking for a source for an owner's manual,
http://www.buffalotools.com/manuals.html
Scroll down to GEN154 - looks like the only one that matches your specs.
Posted on Jun 12, 2010
Testimonial: "Great info!!! This is what I was after. Thank you so very much."
Fred Yearian
  • 5603 Answers
SOURCE: need to know battery ttype
Some of these are delivered with gel cell type batteries. They are often undersized and have limited starting capability.
Frankly the best way I have found is to MEASURE the maximum size fo the battery and note the terminal type. The go to the NAPA site and check the dimensiona to find the biggest battery you can fit in... usually a motorcycle type. Usually you need one that has lugs with holes to use bolts to attach the wires.
Posted on Jul 05, 2010
Anonymous
SOURCE: WHO MANUFACTURES THE ENGINE FOR
There have been several factories in china that have made the motors used on buffalo generators, a couple of these are Lifan and J.D. as in Jiangdong.All of these motors are very similar to honda motors.The 6.5,13,and 15 h.p. motors are real brutes and hold up very well.
Posted on Feb 25, 2011
Buffalo tools 7000 watt 13hp ohv 4 stroke valve clearance
if you cannot get the specs from on line or from a service agent , generally the following apply:-
water cooled engines
inlet hot .010"--exhaust hot .012"
for air cooled engines inlet hot .012"-- exhaust hot .014"
Aug 30, 2015 | Buffalo Tools Electrical Supplies
Generator circuit breaker keeps tripping
wet plugs,exceeding max load of circut,whatever it is running has a short in it.
Dec 21, 2012 | Buffalo Tools Pro-series 7000 Watt Silent...
Do you have a manual for a buffalo tools 2000 watt portable generator?
HOPE THIS LINK WORKS.
http://www.buffalotools.com/manuals/gen154manual.pdf
it is the Gen you got, I have same.. Condenser failed after 7 yrs. Just suddenly stopped putting out. Kept running nicely though!
Oct 28, 2012 | Buffalo Tools Electrical Supplies
I need a gas tank for a 4000 watt Buffalo generator.
call buffalo tool parts dept.they have brand new tanks for $36.75 or if you need a petcock they cost $9.95 they also have the gas gauge for $9.60.call 1-800-568-6657
Feb 01, 2011 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
WHO MANUFACTURES THE ENGINE FOR THE BUFFALO TOOLS GENERATOR EX: 4000 W OR 10000 W SIMPLY PUT WHAT KIND OF ENGINE IS ON ANY OF THEM
Jan 01, 2011 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
4000 watt buffalo tools generator: Engine Starts, but after a few minutes it cuts out and stops running. No appliances plugged in, drained gas(it did sit for 6 months), oil is full, Plug is good.
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Feb 05, 2010 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
Aug 17, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Electrical Supplies Logo
1,443 people viewed this question
Top Electrical Supplies Experts
Marvin
Marvin
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
