I accidentally dialed #65, instead of #62 when trying to access my vmail box, which turned on my outgoing caller ID block. I want the people I'm calling to know it is me, but can't find any information on how to turn the block off. When I try dialing #65 again, it gives me a confirmation that caller ID block is ON. What is the number combo to turn it off??
SOURCE: Making a Polycom SoundPoint 501 work on an Avaya IPO
As you have probably found, SIP phones are not supported until R5, which just came out.
SOURCE: what is the default password for Polycom
Default Passwords:
To get into the web interface, the default username/password is "Polycom"/"456" (Note that this does not work with Safari 1.2.2.)
To get into the Admin interface on the hard phone, the password is "456". (Prior to v1.3.1, the web interfaces to the phone uses "Polycom"/"SpIp" as the username/password.)
The "user password" (not used much) defaults to "123".
To reset a lost admin password to default: at phone boot, during the 5 second countdown, push/hold 468* on the phone. Enter the phone's MAC address as the password. This will reset network info but keep peers loaded. Tested on Soundpoint IP 650.
Testimonial: "Thanx a lot. Although I had managed to find the password for console but the web interface password was still missing. :-)"
SOURCE: i am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
This means the phone's SIP application has been erased. You will need
to download the SIP app and BootROM from the Polycom support page, host
the files on a boot server, and then point the phone to this server
from the server menu so the phone will reboot and download the files.
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
SOURCE: Polycom SoundPoint 550-Only Showing 1 line
On the phone, press the menu button, then status, then IP status or whatever and get the phone's IP address. Write the ip address down. On your computer, open up a web browser and input the phone's IP address into the address bar and press enter. This should arrive you at the web gui for that phone. It'll probably ask you for login credentials; by default, the name is "Polycom" (yes , it is case-sensetive) and the password is 456. Once you are logged in, you should see several links like "General" "Network" "Sip" and "Lines". click on Lines. under "line 1", you will see the configuration for that line. simply duplicate the entries for lines 2, 3, and 4.
Last Updated: Sep 08, 2010You can block your Caller ID information (name and phone number) on a call-by-call basis. Just dial *67 before dialing the number you're calling, and your information will not show up on their Caller ID display.you can also go to http://support.sprint.com/support/article/Know_the_difference_between_restrict_and_block_on_Caller_ID/case-wh164052-20100907-101149?&INTNAV=SU:SP:HDILast Updated: Sep 08, 2010Restrict Caller ID is a restriction that is placed on your account to completely block your information (name and phone number) from being displayed on any call you make. This has to be done by contacting our Customer Care team.Block Caller ID is something you can do yourself directly on your phone by dialing *67 before the number you're calling. This only affects one call at a time, so you have to dial the code before every call you want to block your Caller ID.**************i did some research and found the answer, please provide me with FAIR feed back i.e. 3 or 4 thumbs up. according to sprints website and also htc support forum there is no way to block the caller id automatically. dont kill the messanger i just wanted to pass the info found on htc and through sprint.
