I have a new indesit 7kg a class washing machine and it has been on a constant wash cycle all day
Its model number is iwb7250 i have turned it off and tried to restart it using a 40 degree wash on number 3 but its still going now after 6 hours
Posted by lisa king on
shaun taylor
  • Washing Mach... Master
  • 1,527 Answers
Hi lisa try changing the program put it on a spin cycle see if the program changes if not the programmer timer control could be faulty wihich will be expensive to repair sorry for the bad news
regards
shaun
Posted on Nov 16, 2011
  • lisa king Nov 17, 2011
    thanks shaun i ended up stopping the cycle but could not get water to drain out so i drained it from the filter. i managed to get spin cycle to work was quite noisy as clothes were so wet but now all seems to be fine again so keeping my fingers crossed .
What does Chrono 30 and mAgic 40 stand for
These are names used by Whirlpool for wash programs. Magic 40 is a 1 hour program which washes at 40 degrees, 3-4 Kg of fabrics, for heavy duty cleaning.
Chrono 30 is a short 30 minute program for lightly soiled or dusty clothes.
These seem to occur in Whirlpool machines sold in France.
Jun 02, 2016 | Washing Machines
The wash cycles are taking very long
Sounds like you have a heater problem. Program 5 should take around an hour and 6 should be around 30 min, both with the heater on according to asko's manual. So I would get the heater element checked.
Feb 27, 2012 | Asko W6021 Front Load Washer
Freeezer is only freezing around 26 degrees
Dirty condenser, condenser fan motor is not running, freezer overpacked, bad thermostat, evaporator ice build up and it blocks the air flow. evaporator fan motor is not running or sealed system problem.
Mar 14, 2010 | Freezers
A 40 degree cotton wash takes around 3 hours to complete cycle, manual states 90 minutes, any ideas ?
It is possible the heater element is not working, you need a meter to test it with, and make sure you have selected the correct programm for what you are washing as some programmes can take up to 3 hours to complete.
Hope this helps.
Jan 11, 2010 | Washing Machines
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
Wat number for a simple wash
I f your washer is taking 5 hours to wash, then you have a problem. try a 40 degree wash , it should complete within the hour. I f not , then you need to call someone.
Nov 17, 2008 | Indesit W 123 Front Load Washer
DIal is misaligned!
It could be a faulty water heater stat ,or the hot and cold fill pipes are the wrong way round. close Ireland bye bye
Sep 01, 2006 | Tricity Bendix WDR1040W Front Load Washer...
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
