My fridge has started acted strangely lately. It seems to run all the time and both of the front sides of the bottom freezer are very hot, almost burning to the touch. I hope the service manual could help me figure out the problem. At least it would show me where everything is located inside. Thanks
Clean condenser behind back panel,use a squirt bottle with warm water squirt from top to bottom,should allow it to cycle and not be so hot.
I could not find a service manual (compared to user manual) ... but this link may help:
GE Refrigerator Repair General Electric Refrigerator Repair
Since your unit "seems to run all the time" some things to check:
See the link below it should help you fix the problem Owner Manual Installation Instructions
SOURCE: GE Profile TBX22PC fridge water problems
hi thanks for the question you have a drain problem the drain tube from freezer to the drip pan behind and under neath the fridge you have to clean that drain sometimes you have to shut the fridge down for 24 hrs let the ice melt in the drain tube cause you cant get at it so let thaw and then clean out the drain hose thanks for your question the appliance doc
SOURCE: My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
SOURCE: Water interior of fridge....GE profile 21.6 cubic ft. model #TBX22PIYMRBB
i have this problem .whats the fix
SOURCE: our ge profile side by side started acting up , it
I believe your motherboard has become defective. If you would like my assistance and instructions on how to fix without a Service Technician visit let me know, Sea Breeze
SOURCE: hi i have a ge
Clicking sounds (not immediately preceeded by a power loss) indicate a bad relay on the mother board. Replace the mother board, WR55X10942)
