Question about Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator
F24 Have changed the filter today
Posted by Hilma Schieving on
Anonymous
Fridge is showing f24 fault and wrench symbol. No ice is being made and it peeps continually when door is open
Posted on Dec 28, 2011
  • Jay clarke
    Jay clarke May 11, 2014
    Did anyone find the answer to this?
  • Becker Jun 07, 2015
    I had the same issue. A service guy came out and change the wire for the ice sensor. Apparently the original wires over time break due to constantly getting cold. The new wires are encased in silicon and so far they haven't had them break. He did say f24 can mean a few things but this is the most common.
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Fisher and Paykel French door, freezer drawer, F24 and flashing wrench symbol. Help
That's a water filter error code.
Did you just change the water filter? If not, do so.
If you didn't change it or changing it doesn't solve it, the next step is to ensure there's no air trapped in the system. Get 2 or 3 glasses of water at the door.
If the error code still shows, press and hold the Filter button for 10 seconds which should re-set the code.
If that sorts it out, let us know what worked please. This helps other people with a similar problem know.
However, iIf you still have trouble and the appliance is still in warranty (possibly 2 years or more depending on where you bought it), call the company and provide the model and serial number and they should be able to tell you.
If in warranty, arrange a service call.
If not, let us know what you did and we'll go from there. Good luck!
1helpful
2answers
How can I fix the f24 code on maytag front load washer
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
We are seeing F24 for the first time today on our Kenmore HE2plus front loading washer. What does it mean? How do I solve it?
Hi
F24 is a water temperature sensor error. You have to unplug the washer and check the water temperature sensor and its connections, if that is fine then check the resistance of the heating element and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
4helpful
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
F24 Error code and incessant beeping
Being a software developer I guessed that the keyboard (the touch pad) was bad, because in my case one of the keys (the Top Oven OFF key) did not beep or work. So I went on the Thermador website and found the touchpad on the schematic. I ordered one yesterday from a firm called Mar-Cone in St. Louis, and it arrived today. It is a very easy replacement, and takes about 10 minutes. Happily it was a good guess, and it works fine. For the 27" SEC272BS/01 (stainless) the part # is 474083, and cost $189.20. They will express ship for $25.
Phew, we have 20 people coming for dinner on Thursday.
I'll be happy to let anyone know how to change the panel.
8helpful
Whirlpool duet wahsher
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator Logo
Top Fisher and Paykel Refrigerators Experts
Dan Webster
Dan Webster
Gil Shultz
Jay Finke
Jay Finke
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
