Question about Radio Communications
Got a radioshack trc-487 and I need some information on how to peak and tune it... wheres the modulation pot? which coils do I tune? and whats the numbers on the motherboard
I need help with this cb.... Need to know mods for it...
Posted by Randy Smith on
Iron
  • 3,018 Answers
  • There is no need to send the radio to some unsanctioned moonlighter.
  • I normally don't recommend clipping parts but for this radio there is not much else to do and it looks OK on an Oscilloscope too. Clip diode 205 to increase modulation. Then take a plastic flat tool and spread L 203 coils apart about a 1/8" each, nice and even and make sure they don't touch any metal.
  • Hope this helps.
Posted on Nov 27, 2011
  • 2 more comments
  • AnyMHz.com
    AnyMHz.com Nov 27, 2011
    These users asking to tune up radios.. NEED to have Oscilloscopes or watt meters so they can fix it themselves.. otherwise let shop do it for $5-$10 right.. and NEVER CLIP the mod limiter.. keep it in the 5mhz bandwidth.. PLEASE..
  • Iron
    Iron Nov 27, 2011
    Normally never but as I said with this one is OK. I have yet to see this flat top. Your not talking to a rookie here so get of the soapbox now. If one is running it barefoot then my instructions are a nice tune and about the only tune for this rig. If running with an illegal amplifier then leave stock. Your just trying to get people to unnecessarily send their rigs to your shop when it is not necessary. That's why your profile has been reported.
  • AnyMHz.com
    No Im not! They need to be shown correctly..
  • Iron
    Iron Nov 27, 2011
    Much can be done on here. Not all but a lot can. Almost everyone of your "solutions" is a send it to you response with the occasional how to wire a mic. Talking and instructing someone is not so hard. You just have to know how to slow it down and take the time to explain in detail. If a scope should need to come into play then this can be relayed to them. But you can cut a lot of the cost out of things for them along the way.
Ken A Resendez
If you cut D205 like the first guy said. The radio will not get any power. D205 is the power diode. I'm working on one now. He maybe talking about D105? Not sure yet. The ALC on this radio is small. But I will update as soon as I'm done.
Posted on Apr 13, 2020
AnyMHz.com
    Novelist:
  • 500 Answers
May need some test equipment to tune that one.
You could send it in to us and we can fix it.
We do not charge to look at any radio -no bench fees-..
Let me know Ill get you any info that you need.
Trc 490cb radio
I MIGHT BE WRONG BUT I THINK THE $() ALREADY HAS AN ADJUSTMENT ON THE FRONT OF THE RADIO ITS CALLED THE MIC GAIN THIS CONTROL SHOULD LET YOU ADJUST THE LEVEL WITHOUT GOING INSIDE THE RADIO
Apr 02, 2013 | Radio Shack TRC-447 CB Radio
I have a Radioshack trc-487 cb radio with weather band . I would like to turn up the modulation... Peak and tune... get better reception... anything... I would like to know the internal parts I have to...
Hello Randy, do you have a fiberglass or stainless whip? What is your SWR & power meter readings now? --- The stainless whip may be creating a feedback and picking up static from transformers. Do you have a power microphone? If so you need to use a modulation meter to set it for 100% modulation. It could also be causing the crackling, that or your engine alternator.
A 1:1 SWR implies a perfect match between all elements of the antenna system...this is what you want. If an antenna system is not working well, the power reflected by the antenna will travel back through the transmission line and arrive at the output of the transceiver. From a practical point of view, SWR numbers in the range from 1:1 to 1.5:1 are considered to be very good, meaning that the antenna is radiating most of the power sent to it...
I would not recommend tweaking the boards on the realistic radios. You can however tune your whip. Start by making a base coil with some copper wire, 14 gauge will work. Run one end under the whip mount end and then tightly wrap the wire around the base of the whip. Experiment with 20 - 30 wraps for best performance & SWR.
The Astatic 575M6, or the Sadelta MB-4(hard to find) are very good power microphones that will help with modulation and peak power transmissions. Let me know if you need more help with tuning, if the "crackling" is still there.
Here is a link for your radio, in case you don't have one.
http://support.radioshack.com/support_electronics/36554.htm
Nov 16, 2011 | Radio Communications
Radioshack trc-487
Sorry can not suggest even the addition of a aftermarket mic it would be to much hassle to rewire to that 5 pin plug.
Don't spread coils!!!!
Besides it is an older unit that has obviously set unpowered for long periods this makes it a good candidate for dry capacitors.
Don't forget that antenna system when looking for increased radio performance a good antenna(tall) and good shielded coaxial cable can make or break the setup.
Hope this was of help
I wish to tune and peak a cobra 25 ltd wx. please tell me what pots to turn. I have all of the necessary meters.
do you have a spectrum analyzer? A function generator , bird 43 watt meter,multimeter etc. ? If you have all these then go to www.cbtricks.com and get the information you need .
Sep 06, 2010 | Cobra 25 WX-NW-ST 40-Channels Base CB...
I have no problems just would like to tune and peak my trc-447
RV2 is modulation. turn that up to get full modulation. L9 and L12 is AM power.
Dec 16, 2009 | Radio Shack TRC-447 CB Radio
I was wondering what was the range for the radioshack TRC-447 cb radio with a good cb antenna
Antenna :
-should be tuned, have good coax with no pinches, whip is centered over highest flat metal surface, no metal beside adjacent to whip, power is wired to battery direct, not to ignition or cigg lighter. whip is wiped clean of corrosion, whip is up, longer is better.
Praire City car-to-car: 15-20 km's
Praire Rural car-to-car: four-thirds over the horizon. Probably 60 km's.
Alot further over water.
Less within trees and mountains/valleys.
Google "Ham radio" & "ducting" "inversion" "skip" "sun-spots"
these refer to a condition where a radio signal getting stuck between the upper and lower atmospheres and travel intact for 1000's of km's (canada to mexico for example)
Sep 06, 2009 | Radio Shack TRC-447 CB Radio
Clipping the Mod limitter
DO NOT CLIP THE LIMITER! You may wind up with splattering audio. The best thing you could do is find the modulation pot and turn it a bit to achieve more modulation. I am not familiar with your radio, so I could not tell you where that pot is. You may be disappointed in the results if you clip the limiter.
Jul 16, 2009 | Radio Shack TRC-447 CB Radio
Radio shack trc-447
According to the service manual for the TRC-447, the only adjustment is for "power" which is #L205. The only other step in the transmitter alignment is for the "S" meter.
On the Cobra, VR4 is AMC, L14,L13,L12 is AM power.
Jan 31, 2009 | Radio Shack TRC-447 CB Radio
Need new nonstick pot for my rice cooker TAYAMA TRC-07
Please call 1-866-9TAYAMA and they have all the parts you need
Jun 15, 2008 | Kitchen Appliances - Others
Radio Communications Logo
643 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
