The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
If you have bought GE universal remote for your Vizio TV, then I appreciate because it is best fit for your TV. Works with all IR based TVs, but you should use proper 4-digit remote code.
Then follow 2-3 simple steps.
BOOM, the remote got set to TV.
If you want resource, refer the link below
SOURCE: Need remote control code for ATT U-verse
I HAD THE SAME PROBLEM WITH A VIZIO VL260M. THE CODE 1343 WORKED FOR ME ALSO.
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
I bought a Quantum Fx (REM-102) TV remote control for VIZIO TV but the remote control don't response
I did intent some codes to control programming but don
