This computer was working fine for weeks, then for some reason I had a fatal error that causd a system shutdown. After that the compter would not boot, it reported that it contained an unauthorized network adapter. If I unplug the card it boots fine, plug it in after it bootes and everything works fine. It just doesn't accept it while its booting.
SOURCE: gigabyte k8m800-8237 won't boot with 2nd gig ram installed.
Could have been dusty. Find a copy of Memtest and run it to check things out. Errors could mean a bad stick or bad slot.
SOURCE: after psu burned out , can't boot computer with
You might Have a Short on your Mobo, switch around your Jumper Config, check for any metal material touching any traces :]
hope this helped!
(try reseting stuff aswell, when things vibrate they move IE: chip creep)
SOURCE: Gigabyte GA-VM900M and Inno3D GeForce 7300
just reinstall the operating system.
dont forget to vote
SOURCE: Gigabyte k8m800-8237 wont boot with hard drive
sound like you either have a dead SATA socket on the board, use another one, or at worst try a PATA hard drive, second thought is possibly go into the bios and make sure you have no previous hardware raid arrays left behind, sounds odd.. but i have seen it cause similar problems before.
