The zoom rocker switch is part of the control block assembly and is a common problem on, not only the HF 10 but other models as well. This can be repaired fairly inexpensively but it's not really a user serviceable problem and should be done by a qualified technician. Below is a link to a repair facility that should be able to help you if you need it.
The most likely cause a defective Control Block / zoom rocker switch assembly. This will require major disassembly to repair and can usually be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you would like to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
The lens cover mechanism in these cameras is susceptible to debris and requires disassembling the camera to repair. This can be repaired fairly inexpensively. However, it's not a user serviceable problem due to the fact that the camera will need to be partially disassembled and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
