Brand aficio 3030 and mpc5000 models for Ricoh.once this error comes out the only solution was to replace the main controller which is expensive is there any other solution that can be done.
SOURCE: sc code 672 with aficio 2090
Direct from the service manual:
• Controller board defective
• Controller board installed incorrectly
• Operation panel harness connection loose or incorrect
SOURCE: Scan
Yes you should be able to set up a destination in your address book. The folder must be shared. Click here for the scanner reference for this machine for more information.
Here is a link to all of the other manuals. Hope this helps. Let me know if you need more help.
If this helps you out, please rate this as fix ya.
SOURCE: ricoh aficio 1035 sc code sc 329 troubleshooting
Laser diode beam not positioned correctly. Turn the machine off and back on and see if it goes away. You can run sp 2109-3 or 2109-4 in the service mode to adjust the beam in service mode by pressing on the yellow button. pressing the 107 keys and holding down on the clear button.
If this doesn't resolve the issue, you probably need a laser which we have one for sale here.
SOURCE: Ricoh Aficio 1232c REFILL
You can't use any other brand of color toner to refill the AF1232, you'll have all kinds of issues. They do have compatible toners (generic) for that model but highly recommend OEM.
