Question about SanDisk Sansa e250 MP3 Player
My friend's Sansa SanDisk's screen went wrong. I turn it on and the color is mixed up. I've experienced this with laptops before, but I don't know what it means. What can I do to help it? and what did
Screen is not craked, and the mp3 player doesn't say; "screen broken" and shuts off. I can still use it, and sorda read it , but the color makes it hard.
Posted by Sisey Lola Amanda on
Joe Negus
    President:
  • SanDisk Expert
  • 652 Answers
Take the back off and push down soft but firm on the rubber rectangle..This is the chip-set and the memory...
Posted on Nov 19, 2011
I have a SanDisk Sansa how do I download the music from my Imac to the Sansa, I've connected it to the Imac but I don't see how to downlaod the music
Is the SanDisk showing as a drive on the Imac? You should be able to drag files from the Music folder to the Sansa player to copy them. (You can't connect to ITunes and download directly to the player.)
I hope this helps.
Mar 25, 2013 | SanDisk Sansa Audio Players & Recorders
Song tracks are mixed up on My Sansa Fuse.
What you should do is open the music in windows media player and check the tags and make sure that are all the same. Because SanDisk Organizes by those tags (ie: Artist, album)
Sep 30, 2009 | SanDisk Sansa Fuze MP3 Player
Screen went blank
Hi, I experienced the same problem this morning, my sansa player (e280, 8Gb) froze in the middle of a song, the screen went blank but the wheel still had its blue light on and i didn't know how to fix it bur then i figured how. If that's the case with your player too, then the solution will be to press and hold the power button till the blue light goes off (abt 8-10sec) and then just restart the player. It should work.
May 08, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa e250 won't turn off
My Sansa e250 wanr turn on and i had a full battery whats wrong
Mar 08, 2008 | SanDisk Sansa e250 MP3 Player
Screen color messed up, won't connect correct
well can you come into recovery mode? hold(activated) push rec button and hold it while start your mp4 if it works get me information about it..
Feb 01, 2008 | SanDisk Sansa e250 MP3 Player
My Sandisk e260
press and hold the menu/power button until the player shuts off then wait for 10 seconds then turn the player on. This is usually cause by bad files in the device.
Dec 03, 2007 | SanDisk Sansa e250 MP3 Player
Tried ipod speakers with sansa. Screen went blue and sound went bad.
Dear seren, If you are having trouble with your mp3 player, and you haven't taken it apart, all screws are intact on the backside of the sandisk e250, then you might be able to get it replaced by sandisk, but a hint: don;t ever put your sandisk into an Ipod dock, such as an Ihome. They might have the 30-pin connector similar to the sandisk's, and they might fit into your sandisk, but the Ihomes have a different voltage level than the sandisk's chargers. now, if you want to get an Ihome for your sandisk, Griffin, Macally and DOP brands have chargers, Ihomes, and dock ports made just for the sandisk. Hou do i know this, you ask. Because i have done the same exact thing, but i took mine apart to see what's wrong. It ruins the capacitors and overdrives it. but you can buy the right kind of capacitors at a nearby Radio Shack, but it very difficult to put it on. You have to get the one originally on it off, and that one's soldered ontop the motherboard. then you have to get the other one in just the right spot/ place, and then you have to solder the new capacitor onto the unit without get any solder on the gold linings. This is all i can do for you, the rest is up to you. GOOD LUCK!!! Wild2DMaxx
Aug 28, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
