Using an upgrade disk from vista to win 7 failed and now it will not boot up. i cannot get into safe mode to restore back to prior win 7 installing. There were two upgrade disks one i now know i should have used first however i did not use this as the upgrade advisor said all was well. The startup screen has text refering to winteshi.ini ? any help with this issue Regards Roy
Assuming the restore partition is intact, boot the machine and press and hold F10 and ALT at the same time. If the partition is intact, you should be brought to a restore menu and given the option to restore to factory settings. If this doesn't work, you may have corrupted the restore partition and will need disks to install an operating system. If you created Rescue Disks in Vista, simply load the 1st disk and reboot.
